I'm trying, for the first time, to integrate Cesium in a page where it's not the only page's widget.
I'm doing that in an MDB-based (Bootstrap Material Design free edition: https://mdbootstrap.com/) page.
I started with a very simple layout consisting in a top fixed basic navigation bar and the Cesium's Widget right below it, expecting it to automatically adapt its size to the free space so to filling it.
Unfortunately it doesn't resize properly to the free area, no matter what style I tried.
Without any style applied to the Cesium's container DIV it just overflows (no scrolling bars) the available free space (with other styles it underflows it when the page size is reduced).
If I replace the Cesium DIV with a plain background-colored DIV, or a centered text plain background-colored DIV everything works fine (as intended) in both cases.
What would it be the correct way to place the Cesium's Widget to accomplish my goal? Thanks
I prepared a very simple example
https://mdbootstrap.com/snippets/jquery/vdg/730465
It consists in the most basic sample MDB's Navbar copied and pasted from https://mdbootstrap.com/docs/jquery/navigation/navbar/ (the Avatar orange Navbar example) followed by the 3 different scenarios depicted above:
1) plain background-colored DIV (WORKING)
2) centered text plain background-colored DIV (WORKING)
3) basic Cesium Widget (NOT WORKING)
To test each of them just comment out the others and uncomment it (optionally play with the browser's windows size too), thanks.
I attach screenshots of the mentioned scenarios.
Part of the Cesium's view (when Cesium is displayed) is always invisible.
I'm trying to integrate Cesium in an application where it is not the only GUI element.
Cesium 1.57, Windows 10 64bit, Google Chrome 74.0.3729.157 official build 64bit
