i create a polygon by set hierarchy as a Cesium.CallbackProperty
when i change polygon’s height to 0 after 3 seconds
there is a new polygon created
is this a bug?or I didn’t use cesium.js properly?
In your callbackProperty, make it true which implies that the value is constant. That should solve the problem.
@atul-sd @sam.rothstein
yes,It works.
thank you all.
