Change Timeline from UTC to Local Time
This has been asked several times before however I haven’t seen an answer for this.
Is there a way to view the Timeline in local time format not UTC?
This was answered here: How to fix cesium timezone?. You can override the timeFormatter or dateFormatter functions which take a date/time and return a string that appears in the clock widget.
To handle displaying the timezone correctly you’ll probably want to use another library to take care of that formatting. Here is a JSFiddle that uses the Luxon library to set the time to the user’s local timezone, and you can use this to set the time to a specific timezone as well:
Thank you!
I found something similar however it wasn’t working.
This will assist greatly. Cheers
@omar,
Can the same thing be done for the Timeline bar?
I can see this mentioned in a few spots however I don’t believe makeLabel exists anymore?
_viewer.timeline.makeLabel = function(date) {
var gregorianDate = Cesium.JulianDate.toGregorianDate(date);
return gregorianDate.year;
All,
For timeline bar updates see here:-
My final solution was very basic. In TypeScript it looks like the following if anyone is interested.
       this.viewer.animation.viewModel.dateFormatter = (date, viewModel) => {
          const gregorianDT = JulianDate.toGregorianDate(date);
          const objDate = new Date(gregorianDT.year, gregorianDT.month - 1, gregorianDT.day);
          return gregorianDT.day + ' ' + objDate.toLocaleString('en-us', { month: 'short' }) + ' ' + gregorianDT.year;
        this.viewer.animation.viewModel.timeFormatter = (date, viewModel) => {
          const localDate = JulianDate.toDate(date);
          return localDate.toLocaleTimeString();
this.viewer.animation.viewModel just updates the clock widget but not the labels in the timeline.
The makeLabel method seems to still be there:
It is just marked as private and therefore Typescript does not allow overriding it. However forcing it (with as any) works.
