I have this Cesium based project that consist in showing models and change their position and show property every 4 seconds.
At the moment, I'm just creating all this entities and changing their position with a for that receives the information and search for the correct ID to make the change. If the ID is doesn't exist in the data, the model is hidden.
I have a few questions about this:
1- I'll make a flag that notes if the model doesn't change its position after a few loops and destroy it. Is there a simple away already in Cesium to achieve this?
2- The updated position is received every 4 seconds, but I would like to do something like the HeadingPitchRoll sandcastle example that makes the movement more fluid. I'm trying to read the examples and documentation about primitives and SampledPositionProperty but I'm new to all this and I'm not quite getting it. Anyone has an example or tutorial about this so I can see how it works to try and fit my project to it?
I also notice that in the sandcastle example, the position is changed every render loop, so I tried to change it to setInterval just like I do and it didn't work. Can I preview the velocity of the model based in the two or more lasts positions?
setInterval(function(){
headingSpan.innerHTML = Cesium.Math.toDegrees(hpRoll.heading).toFixed(1);
pitchSpan.innerHTML = Cesium.Math.toDegrees(hpRoll.pitch).toFixed(1);
rollSpan.innerHTML = Cesium.Math.toDegrees(hpRoll.roll).toFixed(1);
speedSpan.innerHTML = speed.toFixed(1);
speedVector = Cesium.Cartesian3.multiplyByScalar(Cesium.Cartesian3.UNIT_X, speed / 10, speedVector);
position = Cesium.Matrix4.multiplyByPoint(planePrimitive.modelMatrix, speedVector, position);
pathPosition.addSample(Cesium.JulianDate.now(), position);
Cesium.Transforms.headingPitchRollToFixedFrame(position, hpRoll, Cesium.Ellipsoid.WGS84, fixedFrameTransform, planePrimitive.modelMatrix);
if (fromBehind.checked) {
// Zoom to model
Cesium.Matrix4.multiplyByPoint(planePrimitive.modelMatrix, planePrimitive.boundingSphere.center, center);
hpRange.heading = hpRoll.heading;
hpRange.pitch = hpRoll.pitch;
camera.lookAt(center, hpRange);
}, 4000);
Thank you,
Maria Eugênia Lagua
