Is it possible to base the camera's orientation and reference point solely on the position and orientation of model?
I'm trying to have the camera follow a model with a SampledPositionProperty and have all camera position and orientation modifications use the current model position as the reference frame. This is partially functional, as the reference frame can easily be set each clock tick with a lookAtTransform at the current position.
The issue I'm having is that the axis still seem to be based on the globe, where even if the orientation of the model is changed the axis are stationary based on the globe. Is there any workaround for this that I'm not seeing?
Thanks in advance,
Alfredo
Sandcastle code modified from an example that shows what I described above :
Essentially, the green polyline always points towards the north pole, the blue away from the center of the globe, and the red to the east. Ideally I'd like to have those directions change with the orientation of the plane, e.g. the red line would extend from the nose of the plane no matter the orientation with the other lines placed relative to that.
terrainProviderViewModels : , //Disable terrain changing
infoBox : false, //Disable InfoBox widget
selectionIndicator : false //Disable selection indicator
//Enable lighting based on sun/moon positions
viewer.scene.globe.enableLighting = true;
//Use STK World Terrain
viewer.terrainProvider = new Cesium.CesiumTerrainProvider({
url : '//cesiumjs.org/stk-terrain/world',
requestWaterMask : true,
requestVertexNormals : true
//Enable depth testing so things behind the terrain disappear.
viewer.scene.globe.depthTestAgainstTerrain = true;
//Set the random number seed for consistent results.
Cesium.Math.setRandomNumberSeed(3);
//Set bounds of our simulation time
var start = Cesium.JulianDate.fromDate(new Date(2015, 2, 25, 16));
var stop = Cesium.JulianDate.addSeconds(start, 360, new Cesium.JulianDate());
//Make sure viewer is at the desired time.
viewer.clock.startTime = start.clone();
viewer.clock.stopTime = stop.clone();
viewer.clock.currentTime = start.clone();
viewer.clock.clockRange = Cesium.ClockRange.LOOP_STOP; //Loop at the end
viewer.clock.multiplier = 10;
//Set timeline to simulation bounds
viewer.timeline.zoomTo(start, stop);
//Generate a random circular pattern with varying heights.
function computeCirclularFlight(lon, lat, radius) {
var property = new Cesium.SampledPositionProperty();
for (var i = 0; i <= 360; i += 45) {
var radians = Cesium.Math.toRadians(i);
var time = Cesium.JulianDate.addSeconds(start, i, new Cesium.JulianDate());
var position = Cesium.Cartesian3.fromDegrees(lon + (radius * 1.5 * Math.cos(radians)), lat + (radius * Math.sin(radians)), Cesium.Math.nextRandomNumber() * 500 + 1750);
property.addSample(time, position);
//Also create a point for each sample we generate.
viewer.entities.add({
position : position,
point : {
pixelSize : 8,
color : Cesium.Color.TRANSPARENT,
outlineColor : Cesium.Color.YELLOW,
outlineWidth : 3
return property;
//Compute the entity position property.
var position = computeCirclularFlight(-112.110693, 36.0994841, 0.03);
//Actually create the entity
//Set the entity availability to the same interval as the simulation time.
availability : new Cesium.TimeIntervalCollection([new Cesium.TimeInterval({
start : start,
stop : stop
//Use our computed positions
//Automatically compute orientation based on position movement.
orientation : new Cesium.VelocityOrientationProperty(position),
//Load the Cesium plane model to represent the entity
model : {
uri : '../../SampleData/models/CesiumAir/Cesium_Air.gltf',
minimumPixelSize : 64
//Show the path as a pink line sampled in 1 second increments.
path : {
resolution : 1,
material : new Cesium.PolylineGlowMaterialProperty({
glowPower : 0.1,
color : Cesium.Color.YELLOW
width : 10
var prim = undefined;
viewer.clock.onTick.addEventListener(function(clock) {
viewer.scene.primitives.remove(prim);
var referencePoint = position.getValue(clock.currentTime);
var transform = Cesium.Transforms.eastNorthUpToFixedFrame(referencePoint, new Cesium.Ellipsoid(500, 500, 500));
prim = viewer.scene.primitives.add(new Cesium.DebugModelMatrixPrimitive({
modelMatrix : transform,
length : 10000.0,
viewer.camera.lookAtTransform(transform, viewer.camera.position.clone());
