ClampToHeightMostDetailed Get the elevation problem
When I use a custom collection PrimitiveCollection when going to load 3 dtileset use clampToHeightMostDetailed access point elevation is always on the ground
var prititives = scene.primitives.add(new Cesium.PrimitiveCollection())
prititives.add(new Cesium.Cesium3DTileset())
Through the mode, the problem is found here
False is always returned because 3DTileset is primititives, not scene.
@111
Thank you very much for bringing this to the community! I read through your post and looked over your code but I am still struggling to understand exactly what issue you are facing here. Could you please provide a little bit more information? A sandcastle demo showcasing the issue would also be helpful. Let me know if you have any other questions or concerns. I am looking forward to learning more about your project!
-Sam
@111
Thank you for sending over the sandcastle demo and the screenshot :rocket:
-Sam
Is this a bug? If yes, when will it be repaired?
@111
I am not sure if this is a bug. Can you please provide an overview of the issue that you are facing here? It seems like the issue is somewhat related to point elevation - is this correct? I am looking forward to learning more :grinning: :rocket:
-Sam
The 3dtileset added by new PrimitiveCollection and the 3dtileset added by scene.primitives.add(), the elevation obtained by clampToHeightMostDetailed is different
@111
Thank you for clarifying. I suggest that you add this as an issue in the CesiumJS GitHub page.
Please let me know when you have done this and I will add details as necessary.
-Sam
