Clock not working properly
The timeline at the bottom seems not to work with the provided start time and stop time.
Regardless of what value I set; it is always set based on the todays day.
        viewer.clock.startTime = sampledPositions.startTime.clone();
        viewer.clock.stopTime = sampledPositions.endTime.clone();
        viewer.clock.currentTime = sampledPositions.startTime.clone();
        viewer.clock.clockRange = Cesium.ClockRange.LOOP_STOP;
viewer.clock.startTime.toString()
"2017-09-08T03:31:46Z"
viewer.clock.stopTime.toString()
"2017-09-08T23:59:58Z"
However, the time line on the bottom shows March 14 2018.
Visualize certain date period.
"cesium": "^1.42.1",
Resolved. I was forgetting to do viewer.timeline.zoomTo
Thanks for updating with your solution!
