Cmake install do not copy lib to \cesium-unreal\Source\ThirdParty
I follow the Developer Setup Guide , use CMake command-line ,but do not generate files in \Source\ThirdParty
C:\Dev\cesium-unreal-samples\Plugins\cesium-unreal\extern\cesium-native\Cesium3DTiles\generated\include\Cesium3DTiles\ClassProperty.h(1): error C2220: 以下警告被视为错误
C:\Dev\cesium-unreal-samples\Plugins\cesium-unreal\extern\cesium-native\Cesium3DTiles\generated\include\Cesium3DTiles\ClassProperty.h(1): warning C4819: 该文件包含不能在当前代码页(936)中表示的字符。请将该文件保存为 Unicode 格式以防止数据丢失
[255/319] Building CXX object cesium-native\Cesium3DTilesWriter\CMakeFiles\Cesium3DTilesWriter.dir\generated\src\TilesetJsonWriter.cpp.obj
FAILED: cesium-native/Cesium3DTilesWriter/CMakeFiles/Cesium3DTilesWriter.dir/generated/src/TilesetJsonWriter.cpp.obj
C:\PROGRA~2\MICROS~3\2019\COMMUN~1\VC\Tools\MSVC\1429~1.301\bin\Hostx64\x64\cl.exe /nologo /TP -DCESIUM3DTILESWRITER_BUILDING -DGLM_FORCE_EXPLICIT_CTOR -DGLM_FORCE_SIZE_T_LENGTH -DGLM_FORCE_XYZW_ONLY -DURI_STATIC_BUILD -I…\cesium-native\Cesium3DTilesWriter\include -I…\cesium-native\Cesium3DTilesWriter\generated\include -I…\cesium-native\Cesium3DTilesWriter\src -I…\cesium-native\Cesium3DTilesWriter\generated\src -I…\cesium-native\Cesium3DTiles\include -I…\cesium-native\Cesium3DTiles\generated\include -I…\cesium-native\CesiumUtility\include -I…\cesium-native\extern\rapidjson\include -I…\cesium-native\extern\glm\glm… -I…\cesium-native\extern\uriparser\include -I…\cesium-native\extern\GSL\include -I…\cesium-native\CesiumJsonWriter\include /DWIN32 /D_WINDOWS /GR /EHsc /Zp8 /Zi /Ob0 /Od /RTC1 -MD /W4 /WX /wd4201 /bigobj -std:c++17 /showIncludes /Focesium-native\Cesium3DTilesWriter\CMakeFiles\Cesium3DTilesWriter.dir\generated\src\TilesetJsonWriter.cpp.obj /Fdcesium-native\Cesium3DTilesWriter\CMakeFiles\Cesium3DTilesWriter.dir\Cesium3DTilesWriter.pdb /FS -c …\cesium-native\Cesium3DTilesWriter\generated\src\TilesetJsonWriter.cpp
[256/319] Building CXX object cesium-native\Cesium3DTilesReader\CMakeFiles\Cesium3DTilesReader.dir\src\SubtreeReader.cpp.obj
[257/319] Building CXX object cesium-native\Cesium3DTilesWriter\CMakeFiles\Cesium3DTilesWriter.dir\generated\src\registerExtensions.cpp.obj
FAILED: cesium-native/Cesium3DTilesWriter/CMakeFiles/Cesium3DTilesWriter.dir/generated/src/registerExtensions.cpp.obj
C:\PROGRA~2\MICROS~3\2019\COMMUN~1\VC\Tools\MSVC\1429~1.301\bin\Hostx64\x64\cl.exe /nologo /TP -DCESIUM3DTILESWRITER_BUILDING -DGLM_FORCE_EXPLICIT_CTOR -DGLM_FORCE_SIZE_T_LENGTH -DGLM_FORCE_XYZW_ONLY -DURI_STATIC_BUILD -I…\cesium-native\Cesium3DTilesWriter\include -I…\cesium-native\Cesium3DTilesWriter\generated\include -I…\cesium-native\Cesium3DTilesWriter\src -I…\cesium-native\Cesium3DTilesWriter\generated\src -I…\cesium-native\Cesium3DTiles\include -I…\cesium-native\Cesium3DTiles\generated\include -I…\cesium-native\CesiumUtility\include -I…\cesium-native\extern\rapidjson\include -I…\cesium-native\extern\glm\glm… -I…\cesium-native\extern\uriparser\include -I…\cesium-native\extern\GSL\include -I…\cesium-native\CesiumJsonWriter\include /DWIN32 /D_WINDOWS /GR /EHsc /Zp8 /Zi /Ob0 /Od /RTC1 -MD /W4 /WX /wd4201 /bigobj -std:c++17 /showIncludes /Focesium-native\Cesium3DTilesWriter\CMakeFiles\Cesium3DTilesWriter.dir\generated\src\registerExtensions.cpp.obj /Fdcesium-native\Cesium3DTilesWriter\CMakeFiles\Cesium3DTilesWriter.dir\Cesium3DTilesWriter.pdb /FS -c …\cesium-native\Cesium3DTilesWriter\generated\src\registerExtensions.cpp
[258/319] Building CXX object cesium-native\Cesium3DTilesReader\CMakeFiles\Cesium3DTilesReader.dir\src\TilesetReader.cpp.obj
[259/319] Building CXX object cesium-native\CesiumGltfWriter\CMakeFiles\CesiumGltfWriter.dir\generated\src\registerExtensions.cpp.obj
FAILED: cesium-native/CesiumGltfWriter/CMakeFiles/CesiumGltfWriter.dir/generated/src/registerExtensions.cpp.obj
C:\PROGRA~2\MICROS~3\2019\COMMUN~1\VC\Tools\MSVC\1429~1.301\bin\Hostx64\x64\cl.exe /nologo /TP -DCESIUMGLTFWRITER_BUILDING -DGLM_FORCE_EXPLICIT_CTOR -DGLM_FORCE_SIZE_T_LENGTH -DGLM_FORCE_XYZW_ONLY -DRAPIDJSON_HAS_CXX11_RVALUE_REFS -DURI_STATIC_BUILD -I…\cesium-native\CesiumGltfWriter\include -I…\cesium-native\CesiumGltfWriter\generated\include -I…\cesium-native\extern\stb -I…\cesium-native\CesiumGltfWriter\src -I…\cesium-native\CesiumGltfWriter\generated\src -I…\cesium-native\CesiumGltf\include -I…\cesium-native\CesiumGltf\generated\include -I…\cesium-native\CesiumUtility\include -I…\cesium-native\extern\rapidjson\include -I…\cesium-native\extern\glm\glm… -I…\cesium-native\extern\uriparser\include -I…\cesium-native\extern\GSL\include -I…\cesium-native\CesiumJsonWriter\include -I…\cesium-native\extern\modp_b64 /DWIN32 /D_WINDOWS /GR /EHsc /Zp8 /Zi /Ob0 /Od /RTC1 -MD /W4 /WX /wd4201 /bigobj -std:c++17 /showIncludes /Focesium-native\CesiumGltfWriter\CMakeFiles\CesiumGltfWriter.dir\generated\src\registerExtensions.cpp.obj /Fdcesium-native\CesiumGltfWriter\CMakeFiles\CesiumGltfWriter.dir\CesiumGltfWriter.pdb /FS -c …\cesium-native\CesiumGltfWriter\generated\src\registerExtensions.cpp
C:\Dev\cesium-unreal-samples\Plugins\cesium-unreal\extern\cesium-native\CesiumGltf\generated\include\CesiumGltf\ExtensionExtStructuralMetadataClassProperty.h(1): error C2220: 以下警告被视为错误
C:\Dev\cesium-unreal-samples\Plugins\cesium-unreal\extern\cesium-native\CesiumGltf\generated\include\CesiumGltf\ExtensionExtStructuralMetadataClassProperty.h(1): warning C4819: 该文件包含不能在当前代码页(936)中表示的字符。请将该文件保存为 Unicode 格式以防止数据丢失
[260/319] Building CXX object cesium-native\CesiumGltfWriter\CMakeFiles\CesiumGltfWriter.dir\generated\src\ModelJsonWriter.cpp.obj
FAILED: cesium-native/CesiumGltfWriter/CMakeFiles/CesiumGltfWriter.dir/generated/src/ModelJsonWriter.cpp.obj
C:\PROGRA~2\MICROS~3\2019\COMMUN~1\VC\Tools\MSVC\1429~1.301\bin\Hostx64\x64\cl.exe /nologo /TP -DCESIUMGLTFWRITER_BUILDING -DGLM_FORCE_EXPLICIT_CTOR -DGLM_FORCE_SIZE_T_LENGTH -DGLM_FORCE_XYZW_ONLY -DRAPIDJSON_HAS_CXX11_RVALUE_REFS -DURI_STATIC_BUILD -I…\cesium-native\CesiumGltfWriter\include -I…\cesium-native\CesiumGltfWriter\generated\include -I…\cesium-native\extern\stb -I…\cesium-native\CesiumGltfWriter\src -I…\cesium-native\CesiumGltfWriter\generated\src -I…\cesium-native\CesiumGltf\include -I…\cesium-native\CesiumGltf\generated\include -I…\cesium-native\CesiumUtility\include -I…\cesium-native\extern\rapidjson\include -I…\cesium-native\extern\glm\glm… -I…\cesium-native\extern\uriparser\include -I…\cesium-native\extern\GSL\include -I…\cesium-native\CesiumJsonWriter\include -I…\cesium-native\extern\modp_b64 /DWIN32 /D_WINDOWS /GR /EHsc /Zp8 /Zi /Ob0 /Od /RTC1 -MD /W4 /WX /wd4201 /bigobj -std:c++17 /showIncludes /Focesium-native\CesiumGltfWriter\CMakeFiles\CesiumGltfWriter.dir\generated\src\ModelJsonWriter.cpp.obj /Fdcesium-native\CesiumGltfWriter\CMakeFiles\CesiumGltfWriter.dir\CesiumGltfWriter.pdb /FS -c …\cesium-native\CesiumGltfWriter\generated\src\ModelJsonWriter.cpp
[261/319] Building CXX object cesium-native\Cesium3DTilesReader\CMakeFiles\Cesium3DTilesReader.dir\generated\src\registerExtensions.cpp.obj
FAILED: cesium-native/Cesium3DTilesReader/CMakeFiles/Cesium3DTilesReader.dir/generated/src/registerExtensions.cpp.obj
C:\PROGRA~2\MICROS~3\2019\COMMUN~1\VC\Tools\MSVC\1429~1.301\bin\Hostx64\x64\cl.exe /nologo /TP -DCESIUM3DTILESREADER_BUILDING -DGLM_FORCE_EXPLICIT_CTOR -DGLM_FORCE_SIZE_T_LENGTH -DGLM_FORCE_XYZW_ONLY -DURI_STATIC_BUILD -I…\cesium-native\Cesium3DTilesReader\include -I…\cesium-native\Cesium3DTilesReader\generated\include -I…\cesium-native\Cesium3DTilesReader\src -I…\cesium-native\Cesium3DTilesReader\generated\src -I…\cesium-native\Cesium3DTiles\include -I…\cesium-native\Cesium3DTiles\generated\include -I…\cesium-native\CesiumUtility\include -I…\cesium-native\extern\rapidjson\include -I…\cesium-native\extern\glm\glm… -I…\cesium-native\extern\uriparser\include -I…\cesium-native\extern\GSL\include -I. -I…\cesium-native\CesiumJsonReader\include /DWIN32 /D_WINDOWS /GR /EHsc /Zp8 /Zi /Ob0 /Od /RTC1 -MD /W4 /WX /wd4201 /bigobj -std:c++17 /showIncludes /Focesium-native\Cesium3DTilesReader\CMakeFiles\Cesium3DTilesReader.dir\generated\src\registerExtensions.cpp.obj /Fdcesium-native\Cesium3DTilesReader\CMakeFiles\Cesium3DTilesReader.dir\Cesium3DTilesReader.pdb /FS -c …\cesium-native\Cesium3DTilesReader\generated\src\registerExtensions.cpp
[262/319] Building CXX object cesium-native\CesiumGltfReader\CMakeFiles\CesiumGltfReader.dir\src\decodeDraco.cpp.obj
[263/319] Building CXX object cesium-native\Cesium3DTilesReader\CMakeFiles\Cesium3DTilesReader.dir\generated\src\GeneratedJsonHandlers.cpp.obj
FAILED: cesium-native/Cesium3DTilesReader/CMakeFiles/Cesium3DTilesReader.dir/generated/src/GeneratedJsonHandlers.cpp.obj
C:\PROGRA~2\MICROS~3\2019\COMMUN~1\VC\Tools\MSVC\1429~1.301\bin\Hostx64\x64\cl.exe /nologo /TP -DCESIUM3DTILESREADER_BUILDING -DGLM_FORCE_EXPLICIT_CTOR -DGLM_FORCE_SIZE_T_LENGTH -DGLM_FORCE_XYZW_ONLY -DURI_STATIC_BUILD -I…\cesium-native\Cesium3DTilesReader\include -I…\cesium-native\Cesium3DTilesReader\generated\include -I…\cesium-native\Cesium3DTilesReader\src -I…\cesium-native\Cesium3DTilesReader\generated\src -I…\cesium-native\Cesium3DTiles\include -I…\cesium-native\Cesium3DTiles\generated\include -I…\cesium-native\CesiumUtility\include -I…\cesium-native\extern\rapidjson\include -I…\cesium-native\extern\glm\glm… -I…\cesium-native\extern\uriparser\include -I…\cesium-native\extern\GSL\include -I. -I…\cesium-native\CesiumJsonReader\include /DWIN32 /D_WINDOWS /GR /EHsc /Zp8 /Zi /Ob0 /Od /RTC1 -MD /W4 /WX /wd4201 /bigobj -std:c++17 /showIncludes /Focesium-native\Cesium3DTilesReader\CMakeFiles\Cesium3DTilesReader.dir\generated\src\GeneratedJsonHandlers.cpp.obj /Fdcesium-native\Cesium3DTilesReader\CMakeFiles\Cesium3DTilesReader.dir\Cesium3DTilesReader.pdb /FS -c …\cesium-native\Cesium3DTilesReader\generated\src\GeneratedJsonHandlers.cpp
[264/319] Building CXX object cesium-native\CesiumGltfReader\CMakeFiles\CesiumGltfReader.dir\generated\src\registerExtensions.cpp.obj
FAILED: cesium-native/CesiumGltfReader/CMakeFiles/CesiumGltfReader.dir/generated/src/registerExtensions.cpp.obj
C:\PROGRA~2\MICROS~3\2019\COMMUN~1\VC\Tools\MSVC\1429~1.301\bin\Hostx64\x64\cl.exe /nologo /TP -DBASISU_NO_ITERATOR_DEBUG_LEVEL -DCESIUMGLTFREADER_BUILDING -DGLM_FORCE_EXPLICIT_CTOR -DGLM_FORCE_SIZE_T_LENGTH -DGLM_FORCE_XYZW_ONLY -DKHRONOS_STATIC -DKTX_FEATURE_KTX1 -DKTX_FEATURE_KTX2 -DLIBASYNC_STATIC -DSPDLOG_COMPILED_LIB -DURI_STATIC_BUILD -I…\cesium-native\extern\asyncplusplus\include -I…\cesium-native\extern\KTX-Software\include -I…\cesium-native\extern\draco\src -I…\cesium-native\CesiumGltfReader\include -I…\cesium-native\CesiumGltfReader\generated\include -I…\cesium-native\extern\stb -I…\cesium-native\CesiumGltfReader\src -I…\cesium-native\CesiumGltfReader\generated\src -I…\cesium-native\extern\rapidjson\include -I…\cesium-native\CesiumAsync\include -I…\cesium-native\extern\spdlog\include -I…\cesium-native\CesiumUtility\include -I…\cesium-native\extern\glm\glm… -I…\cesium-native\extern\uriparser\include -I…\cesium-native\extern\GSL\include -I…\cesium-native\CesiumGltf\include -I…\cesium-native\CesiumGltf\generated\include -I. -I…\cesium-native\CesiumJsonReader\include -I…\cesium-native\extern\modp_b64 /DWIN32 /D_WINDOWS /GR /EHsc /Zp8 /Zi /Ob0 /Od /RTC1 -MD /W4 /WX /wd4201 /bigobj /Zc:__cplusplus -std:c++17 /showIncludes /Focesium-native\CesiumGltfReader\CMakeFiles\CesiumGltfReader.dir\generated\src\registerExtensions.cpp.obj /Fdcesium-native\CesiumGltfReader\CMakeFiles\CesiumGltfReader.dir\CesiumGltfReader.pdb /FS -c …\cesium-native\CesiumGltfReader\generated\src\registerExtensions.cpp
[265/319] Building CXX object cesium-native\CesiumGltfReader\CMakeFiles\CesiumGltfReader.dir\src\GltfReader.cpp.obj
[266/319] Building CXX object cesium-native\CesiumGltfReader\CMakeFiles\CesiumGltfReader.dir\generated\src\GeneratedJsonHandlers.cpp.obj
FAILED: cesium-native/CesiumGltfReader/CMakeFiles/CesiumGltfReader.dir/generated/src/GeneratedJsonHandlers.cpp.obj
C:\PROGRA~2\MICROS~3\2019\COMMUN~1\VC\Tools\MSVC\1429~1.301\bin\Hostx64\x64\cl.exe /nologo /TP -DBASISU_NO_ITERATOR_DEBUG_LEVEL -DCESIUMGLTFREADER_BUILDING -DGLM_FORCE_EXPLICIT_CTOR -DGLM_FORCE_SIZE_T_LENGTH -DGLM_FORCE_XYZW_ONLY -DKHRONOS_STATIC -DKTX_FEATURE_KTX1 -DKTX_FEATURE_KTX2 -DLIBASYNC_STATIC -DSPDLOG_COMPILED_LIB -DURI_STATIC_BUILD -I…\cesium-native\extern\asyncplusplus\include -I…\cesium-native\extern\KTX-Software\include -I…\cesium-native\extern\draco\src -I…\cesium-native\CesiumGltfReader\include -I…\cesium-native\CesiumGltfReader\generated\include -I…\cesium-native\extern\stb -I…\cesium-native\CesiumGltfReader\src -I…\cesium-native\CesiumGltfReader\generated\src -I…\cesium-native\extern\rapidjson\include -I…\cesium-native\CesiumAsync\include -I…\cesium-native\extern\spdlog\include -I…\cesium-native\CesiumUtility\include -I…\cesium-native\extern\glm\glm… -I…\cesium-native\extern\uriparser\include -I…\cesium-native\extern\GSL\include -I…\cesium-native\CesiumGltf\include -I…\cesium-native\CesiumGltf\generated\include -I. -I…\cesium-native\CesiumJsonReader\include -I…\cesium-native\extern\modp_b64 /DWIN32 /D_WINDOWS /GR /EHsc /Zp8 /Zi /Ob0 /Od /RTC1 -MD /W4 /WX /wd4201 /bigobj /Zc:__cplusplus -std:c++17 /showIncludes /Focesium-native\CesiumGltfReader\CMakeFiles\CesiumGltfReader.dir\generated\src\GeneratedJsonHandlers.cpp.obj /Fdcesium-native\CesiumGltfReader\CMakeFiles\CesiumGltfReader.dir\CesiumGltfReader.pdb /FS -c …\cesium-native\CesiumGltfReader\generated\src\GeneratedJsonHandlers.cpp
ninja: build stopped: subcommand failed.
安装成功。
