colorByDistance use dynamic locations
I am new with cesium and I am trying to visualize 3D tiles using a location provided by a user but the code measures distance from a fixed latitude longitude (-1.291777521, 0.7105706624).
I am not able to put a variable in place of these values.
// Color buildings by distance from a landmark.
function colorByDistance() {
    tileset.style = new Cesium.Cesium3DTileStyle({
        defines : {
            distance : "distance(vec2(\{longitude\}, {latitude}), vec2(-1.291777521, 0.7105706624))"
        color : {
            conditions : [
                ["\{distance\} > 0\.0002", "color\('gray'\)"\],                 \["true", "mix\(color\('yellow'\), color\('green'\), {distance} / 0.0002)"]
I want users to drop a geometry on the map and the map should visualize according to the distance from the central location and the size of the geometry .
Cesium 1.57 with Google Chrome
You can append your longitude/latitude to that string instead of using this fixed value. So instead of:
distance : “distance(vec2({longitude}, {latitude}), vec2(-1.291777521, 0.7105706624))”
You would have:
var longitude = -1.2;
var latitude = 0.7;
distance : “distance(vec2({longitude}, {latitude}), vec2(” + longitude + ", " + latitude + “))”
Let me know if that works for you!
