CompositeEntityCollection
It is unclear how to use a composite entity collection. Our purpose is to be able to quickly add/remove groups of entities (we have over 10,000 across the entire globe)
here is a code sample:
createCustomDataSource: function() {
    var scope = this;
    scope.viewer = this.getCmp()._cesium;
    //create datasource
    scope._CoTDataSource = new Cesium.CustomDataSource();
    //add data source
    scope.viewer.dataSources.add(scope._CoTDataSource);
    //create composite entity collection
    scope.collections = new Cesium.CompositeEntityCollection();
    scope._CoTDataSource.entityCollections = scope.collections;
    scope.defaultCollection = new Cesium.EntityCollection();
    scope.collections.addCollection(scope.defaultCollection);
    scope.viewer.clock.onTick.addEventListener(function() {
        scope.processData();
I’m not sure what your exact use case is, but if you’re just trying to show/hide groups of entities, you could use a parent entity for each group. See this example: http://cesiumjs.org/Cesium/Apps/Sandcastle/index.html?src=Show%20or%20Hide%20Entities.html&label=Beginner
CustomDataSource does not have an entityCollections property. It has an entities property to get the EntityCollection, but that is read only.
In order to have CustomDataSource use a CompositeEntityCollection, you will have to make changes to the code: https://github.com/AnalyticalGraphicsInc/cesium/blob/master/Source/DataSources/CustomDataSource.js#L41
Hannah
That is a perfect solution! Thanks
