Is there any way to not show this slider(as in screenshot below) on click of few polygons but to show on click of few other polygons? To simplify what I mean to say, suppose This slider should be shown on click of blue polygon but should not be shown when red polygon is clicked, but I want to keep the ids for both polygons.
In the meantime, you can write a custom click handler to set the selected and tracked entities. Here is a code example:
// Remove old click handlers
viewer.cesiumWidget.screenSpaceEventHandler.removeInputAction(Cesium.ScreenSpaceEventType.LEFT_CLICK);
viewer.cesiumWidget.screenSpaceEventHandler.removeInputAction(Cesium.ScreenSpaceEventType.LEFT_DOUBLE_CLICK);
function selectEntity(event) {
var picked = viewer.scene.pick(event.position);
if (Cesium.defined(picked)) {
var id = Cesium.defaultValue(picked.id, picked.primitive.id);
if (id instanceof Cesium.Entity && [INSERT CONDITION HERE]) {
viewer.selectedEntity = id;
function trackEntity(event) {
viewer.trackedEntity = id;
// Set new click handlers
viewer.cesiumWidget.screenSpaceEventHandler.setInputAction(selectEntity, Cesium.ScreenSpaceEventType.LEFT_CLICK);
viewer.cesiumWidget.screenSpaceEventHandler.setInputAction(trackEntity, Cesium.ScreenSpaceEventType.LEFT_DOUBLE_CLICK);
For example, if you only wanted to select opaque ellipses, you could add this condition: id.ellipse.material.getValue(viewer.clock.currentTime).color.alpha === 1.0
It worked for the polygons for which I do not want to show infobox. But the infobox does not show the ID of selected entity when clicked for other polygons.
