CORS policy change this morning?
We are getting (many) errors similar to following on Cesium load, and some functionality is not working :
Access to XMLHttpRequest at ‘http://cesiumjs.org/releases/1.58/Build/Cesium/Assets/approximateTerrainHeights.json’ from origin****** has been blocked by CORS policy: No ‘Access-Control-Allow-Origin’ header is present on the requested resource.
Access to XMLHttpRequest at ‘http://cesiumjs.org/releases/1.58/Build/Cesium/Assets/Textures/SkyBox/tycho2t3_80_mx.jpg’ from origin ****** has been blocked by CORS policy: No ‘Access-Control-Allow-Origin’ header is present on the requested resource.
It was working fine until yesterday. Starting this morning we are getting this error
We are using 1.58, but same behavior is in 1.60
Back to normal now!
But still still not working for test environment using localhost
There has indeed been a change, which has been reverted, see: https://github.com/AnalyticalGraphicsInc/cesium/issues/8050
Are you still having issues?
Out testing environment runs over HTTP and was loading Cesium over HTTP. And still fails if doing so.
Changing Cesium links to HTTPS fixed the issue
