Create a circle on an entity
I am creating the following entity:
var randomColor = Cesium.Color.fromRandom({alpha: 0.8});
var plane= Cesium.entities.add({
position: new Cesium.Cartesian3.fromDegrees(parseFloat(planePosition.x), parseFloat(planePosition.y), parseFloat(planePosition.z)),
billboard: {
scale: 0.9,
image: icon,
rotation: Cesium.Math.toRadians(parseFloat(angle)),
polyline: {
positions: [new Cesium.Cartesian3.fromDegrees(parseFloat(planePosition.x), parseFloat(planePosition.y), parseFloat(planePosition.z)),
new Cesium.Cartesian3.fromDegrees(parseFloat(center.x), parseFloat(center.y), parseFloat(center.z))],
width: 3.5,
material: randomColor
The coordinates/angle values (center, planePosition, angle) I receive from AJAX communication.
I need to add a circle of the orbit that the plane is doing.
  1. Can I add it as a part of the same entity?
  2. How do I create a circle, with no fill, just outline?
Many tests using the sandcastle did not work.
Thanks.
Hi there,
Checkout this example, which sounds similar to your case: http://cesiumjs.org/Cesium/Apps/Sandcastle/index.html?src=Interpolation.html&label=Showcases
Entity.path sounds like what you need.
Hope that helps,
  • Rachel
Rachel,
Thanks a lot this is exactly what I needed.
Kfir.
