Create loading spinner
I am adding a czml file to the viewer. How to create a loading sippner until the data is fully loaded?
@fation
Thank you for your post! I looked through our community forum and our sandcastle gallery. I did not find an easy way to add a loading spinner while the CZML data is loading in. Do other community members have suggestions?
-Sam
Hi @fation,
You can add a HTML element to your code, like follows:
<div id = "spinner">
  <img src="spinner url here" />
</div>
Then, in your script, include something similar to below.
var czml = "......"; // put your CZML here
var viewer = new Cesium.Viewer("cesiumContainer");
var spinner = document.getElementById("spinner");
var dataSource = new Cesium.CzmlDataSource();
var dataSourcePromise = dataSource.load(czml).then(function() {
  viewer.zoomTo(dataSource);
  spinner.style.display = "none";
Hope this helps!
Best regards,
Janine
Thank you @janine .
I already have implemented the same way :smiley:
