Creating a trailing path to follow a moving entity (billboard)
I would like to have a trailing orange path behind movement of my billboard entity. I am programmatically controlling its movement (it is coming from a live remote sensor). The the actual SVG/Canvas for the symbol comes from: https://github.com/spatialillusions/milsymbol
But the point is that I am clearly making an error in how to setup the PATH attribute of the entity. I don’t see a trailing or leading path. What am I doing wrong?
makeGlyph(sprite) {
let milSym = milSymbols[sprite.type]
if (milSym === undefined) milSym = milSymbols[“UFO”]
sprite.mps = 0
sprite.symbol = milSym
let sym2 = new ms.Symbol(milSym, { size: 26, type: sprite.marking, speed: sprite.mps + ’ mps’, direction: sprite.heading, infoColor: “red” })
let glyph = new Cesium.Entity({
position: Cesium.Cartesian3.fromDegrees(sprite.lon, sprite.lat, sprite.altitude),
billboard: {
image: sym2.asCanvas(), //Get the canvas for the billboard
// heightReference : Cesium.HeightReference.CLAMP_TO_GROUND,
pixelOffset: new Cesium.Cartesian2(-sym2.markerAnchor.x, -sym2.markerAnchor.y), // Symbol offset
eyeOffset: new Cesium.Cartesian3(0.0, 0.0, 0.0), // default
horizontalOrigin: Cesium.HorizontalOrigin.LEFT, // default
verticalOrigin: Cesium.VerticalOrigin.TOP
path: {
leadTime: 100,
trailTime: 100,
width: 1,
material: new Cesium.ColorMaterialProperty({
color : Cesium.Color.ORANGE,
label: {
text: sprite.marking,
font: ‘14pt monospace’,
style: Cesium.LabelStyle.FILL_AND_OUTLINE,
outlineWidth: 1,
verticalOrigin: Cesium.VerticalOrigin.BOTTOM,
pixelOffset: new Cesium.Cartesian2(0, -20)
sprite.glyph = glyph
this.infoBox(sprite)
this.viewer.entities.add(glyph)
updateGlyph(sprite) {
this.viewer.entities.suspendEvents()
let loc = Cesium.Cartesian3.fromDegrees(sprite.lon, sprite.lat, sprite.altitude)
sprite.mps = sprite.speed[0] + sprite.speed[1] + sprite.speed[2]
sprite.glyph.position = loc;
this.viewer.entities.resumeEvents()
killGlyph(sprite) {
this.viewer.entities.removeById(sprite.id)
We are tracking live aircraft and pedestrians, and we are showing the current map position with a billboard. But we would like to see a trailing path of where they have traveled for the last N seconds. We thought that Entity.path was the correct attribute to set on creation.
Cesium 1.39, Chrome 61
Make sure you are viewing it within +/- 100 seconds of it's last position. You could try changing the trail/lead time to 1000000 and see if it shows up. Also try removing the trailTime and leadTime options and verify the entire path shows up (which is what should happen if you don't specify a trailTime and leadTime).
How are you controlling the position? You set the position as a Cartesian3, which doesn't have any time associated with it. You probably need to be using a SampledPositionProperty, like this:
var position = new Cesium.SampledPositionProperty();
position.addSample(time, pos); // where time is a JulianDate and pos is a Cartesian3
Then:
   position: position,
Later you can add more positions by:
var entity = this.viewer.entities.getById(id);
entity.position.addSample(time, pos);
Hope that helps.
Hi there,
Steven is correct. a Path Entity is just a Polyline which describes the entity’s path. You need to define the position as a property that can be sampled with time, rather than directly updating the position to a constant.
Gabby
