HI Gabby-Getz
I’m sorry, I think the code I sent is wrong. Here is my code:
const czml =[{
“id”: “document”,
“name”: “OceanoVox_0”,
“version”: “1.0”,
“clock”: {
“currentTime”: “2022-07-19T14:34:58.000Z”,
“interval”: “2022-07-18T06:34:44.000Z/2022-08-16T21:39:49.000Z”,
“multiplier”: 1
“id”: “v1”,
“availability”: “2022-07-19T14:34:58.000Z/2022-08-16T21:39:49.000Z”,
“model”: {
“gltf”: “…/SampleData/models/CesiumAir/Cesium_Air.glb”,
“scale”: 5.0,
“heightReference”: “Cesium.HeightReference.CLAMP_TO_GROUND”
// “clampToGround”: true,
“show”: [{
“boolean”: true
“position”: {
“cartographicDegrees”: [
“2022-07-19T14:34:58.000Z”, -23.4516, 66.2113, 100,
“2022-07-19T18:34:59.000Z”, -24.5343, 66.0678,100,
“2022-07-19T19:35:00.000Z”, -24.7856, 66.0116, 100,
“2022-07-19T21:35:07.000Z”, -25.3791, 65.9415, 100,
“2022-07-19T22:35:09.000Z”, -25.6425, 65.9128, 100,
“2022-07-20T01:35:05.000Z”, -26.4321, 65.8438, 100,
“2022-07-20T03:35:03.000Z”, -26.8433, 65.7891,100,
“2022-07-20T04:35:54.000Z”, -27.076, 65.7511, 100,
“2022-07-20T05:36:07.000Z”, -27.3155, 65.7178,100,
“2022-07-20T06:35:04.000Z”, -27.5348, 65.6838, 100,
“2022-07-20T08:35:35.000Z”, -27.9558, 65.6418, 100,
“2022-07-20T11:35:07.000Z”, -28.6628, 65.5985,100,
“2022-07-20T12:36:01.000Z”, -28.8986, 65.5838, 100,
“2022-07-20T13:35:35.000Z”, -29.104, 65.56350,100],
“epoch”: “2022-07-19T14:34:58.000Z”,
“interpolationAlgorithm”: “LAGRANGE”,
“interpolationDegree”: 1
“orientation”: {
“velocityReference”: “#position”
const viewer = new Cesium.Viewer(“cesiumContainer”, {
shouldAnimate: true,
var options = {
fullscreenButton: true,
sceneModePicker: false,
terrainProvider : Cesium.createWorldTerrain({
requestWaterMask : true,
requestVertexNormals : true
const viewer = new Cesium.Viewer(“cesiumContainer”, options);
viewer.scene.globe.depthTestAgainstTerrain = true;
const dataSourcePromise = viewer.dataSources.add(
Cesium.CzmlDataSource.load(czml)
dataSourcePromise
.then(function (dataSource) {
viewer.trackedEntity = dataSource.entities.getById(
“v1”
.catch(function (error) {
window.alert(error);
This code work fine, but when I replace :
const viewer = new Cesium.Viewer(“cesiumContainer”, { shouldAnimate: true, });
by the code in comments to see water mask, the plane is sinking.
