czml load file, then czml stream?
No problem yet, I just want to make sure this will work before I start tackling it.
What I’d like to do is have the client load a set of open “sites” at when they first access the url. Then provide updates via Server Side Events streamed to those same sites. I think the best way to do this is to generate a czml when the client access the url and then load that via CzmlDataSource.load(). Then later point a CzmlDataSource.process to a url which will provide server side event czml data. So in effect this will load the current state of open sites and keep updating it. Does this sound like the best way to do this? Is there a way to provide a czml packet that closes the site? Maybe just provide an interval end time which has already passed?
Thanks in advance.
