I initially call Datasource.load(czml), where I load the czml data, then anytime i make changes I call DataSource.process(czml)
So the problem is, I’m now adding so much data that the internal buffer for Cesium (some assumptions made here) that the processed czml goes into to be rendered fills up to such a long array that it slows down the UI framerate.
So I’m attempting to call Datasource.load(czml) every 15seconds to clear out any lingering data in the buffer to put more data in it. But apparently it doesn’t work like that, Cuz after the first 15seconds, the UI stops rendering any new cmzl data after the second DataSource.load(czml) call.
How do I clear out that internal rendering buffer for more data if DataSource.load() doesn’t do that?
2. A minimal code example.
For how I acquire the data go visit the other ticket I posted, but the main problem is shown below: https://groups.google.com/forum/#!topic/cesium-dev/-p8OKRAeaME
if (load_layer1) { //load_layer1 is set to true every 15seconds by a setInterval call
DS_layer1.load(camera_data);
load_layer1 = false;
} else {
DS_layer1.process(camera_data);
I’m trying to process a lot of data via websockets, I processing approx. 4000 PNT (position, navigation, timing) packets every minute.
Running 1.41 on chrome (windows 10) with a developer grade laptop.
