It’s been a long time ever since I contributed to Cesium - but I’d be happy to come back
What I’m missing (it probably exists, I just couldn’t find it) is the following:
test with “watch” option
test only a specific or failed suite
combine with “watch”
Is this available with current infra?
Thanks!
For testing, if you mean running CesiumJS with your code changes locally, you should be able to fire up Sandcastle locally, which will load the code from the Source folder, so there’s no need to run build/combine to see your changes (unless you’re making changes to a shader or a worker, then you just need to npm run build). There is also a npm run build-watch in the gulpfile for automatically doing this.
