I want to show bing map on high levels, and show open street map on low levels.
Can anyone tell me how to implement it?
I have tried by setting max levels and min levels for each layers, but it doesn’t work.
I also want to change the transparency of each layers, but I can barely find a way to get “level” of current view.
Thanks.
Sure, but you know, I need to know when I change the Transparency, which means I need a so-called “level” thing to trigger the changing transparency event.
Thanks.
Can anyone help?
This is pretty non-obvious and should be made easier, but here’s a complete example that does what you want (you can paste it into Sandcastle). The key is constructing the ImagerLayer with the correct minimumTerrainLevel and maximumTerrainLevel options.
baseLayerPicker : false
var bingProvider = new Cesium.BingMapsImageryProvider({
url : ‘//dev.virtualearth.net’,
mapStyle : Cesium.BingMapsStyle.AERIAL
var osmProvider = new Cesium.OpenStreetMapImageryProvider({
url : ‘//a.tile.openstreetmap.org/’
var layers = viewer.imageryLayers;
layers.removeAll();
var bingLayer = layers.add(new Cesium.ImageryLayer(bingProvider, {
maximumTerrainLevel : 6
var osmLayer = layers.add(new Cesium.ImageryLayer(osmProvider, {
minimumTerrainLevel : 7
