When i write below code and host .terrain files on Tomcat, i can correctly see elevations of an area:
var terrainProvider = new Cesium.CesiumTerrainProvider({
url: 'http://localhost:8080/terrain/terrain_52_06'
this.scene.terrainProvider = terrainProvider;
But, when i write below code and host .terrain files on nodejs server, i can see elevations of the area, but in addition to that i can see elevated spikes all over map on the globe also:
url: 'http://localhost:3005/terrain/terrain_52_06'
Basically, my app runs on node server at: http://localhost:3005. So, in the Tomcat case, i enable CORS and then it works, whereas in Node server i dont need CORS.
Hi there,
If you navigate to the tile directly in the browser, do you get the exact same file back in both cases? Also, is the terrain pre-gzipped? If so, are you setting the content-encoding to indicate that it is in both cases? Apart from that, it sounds like this is a server configuration issue which will be tricky to help with without knowing the exact details for both servers.
Hope that helps,
When i navigate to the .terrain file directly from the browser i get exact same file on both cases!
Terrain is not zipped. I am using .terrain files generated from a .tif file using gdal2srtmtiles.py script.
This is such a strange issue i am facing!
In case of tomcat, i am placing the terrain folder inside webapps folder.
In case of node, i am placing the terrain folder inside public folder and accessing using:
app.use(’/terrain’, express.static(__dirname + ‘/public/terrain/terrain_52_06’));
