Hi everyone, I'm trying to add some additional images around my billboards that need to be generated dynamically, and I'm having a hard time figuring out how to do that. For example, I would like to draw an arc around my billboard that represents the amount of fuel that has been used (as a percentage). So if 50% of the fuel is gone, my arc will go halfway around the billboard. Also, I need to be able to make custom labels that require styling beyond what is available in the Label object. I would also like to be able to have the user interact with those things (so clicking on the fuel status arc would trigger something, etc).
I don't think I can use the built-in drawing capabilities for the arc (using splines, for example) because it seems like they're represented geographically, and therefore, when I zoom in, the arc gets bigger in relation to my billboard.
It seems like the easiest way for me to be able to accomplish this would be to have a way to insert a dynamically generated SVG at the same location as my normal billboard for the arc, and HTML for my custom label. The reason I want to use a dynamically generated SVG is because I need each item on my Cesium map to have its own fuel status representation, and I want it to be pretty accurate, and I need to be able to change the colors depending on if the fuel is low, etc.
I started down that path by trying to inserta data URI containing HTML into the billboard's image field (in my CZML), but it does not display anything. I figured if I could do that, then I could just create another billboard in addition to the one representing the aircraft that would have the HTML (or even better, an SVG path). Note that when I put a base64 string representation of a png as the billboard, it does work - just not when I try to use HTML or plain text instead, such as:
"data:,Hello%2C%20World!"
or
"data:text/html,%3Ch1%3EHello%2C%20World!%3C%2Fh1%3E"
Can anyone tell me what my options are for creating custom markup/images around my billboards?
