Hi!
I am trying to re-use the example on Sandcastle Drawing on terrain, the idea is to build a tool for adding different types of soil, lines, including points. I managed to create styled lines and polygons but not points. Please, See below how I am trying to insert a points.
viewer.cesiumWidget.screenSpaceEventHandler.removeInputAction(Cesium.ScreenSpaceEventType.LEFT_DOUBLE_CLICK);
function createPoint(worldPosition) {
var point = viewer.entities.add({
position : worldPosition,
point : {
color : Cesium.Color.WHITE,
pixelSize : 5,
heightReference: Cesium.HeightReference.CLAMP_TO_GROUND
return point;
var drawingMode = 'line';
function drawShape(positionData) {
var shape;
if (drawingMode === 'line') {
shape = viewer.entities.add({
polyline : {
positions : positionData,
clampToGround : true,
width : 3
if (drawingMode === 'point') {
point : {
color : Cesium.Color.BLACK,
pixelSize : 10,
else if (drawingMode === 'polygon') {
polygon: {
hierarchy: positionData,
material: new Cesium.ColorMaterialProperty(Cesium.Color.WHITE.withAlpha(0.7))
return shape;
var activeShapePoints = ;
var activeShape;
var floatingPoint;
var handler = new Cesium.ScreenSpaceEventHandler(viewer.canvas);
handler.setInputAction(function(event) {
// We use `viewer.scene.pickPosition` here instead of `viewer.camera.pickEllipsoid` so that
// we get the correct point when mousing over terrain.
var earthPosition = viewer.scene.pickPosition(event.position);
// `earthPosition` will be undefined if our mouse is not over the globe.
if (Cesium.defined(earthPosition)) {
if (activeShapePoints.length === 0) {
floatingPoint = createPoint(earthPosition);
activeShapePoints.push(earthPosition);
var dynamicPositions = new Cesium.CallbackProperty(function () {
return activeShapePoints;
}, false);
activeShape = drawShape(dynamicPositions);
if (Cesium.defined(floatingPoint)) {
var newPosition = viewer.scene.pickPosition(event.endPosition);
if (Cesium.defined(newPosition)) {
floatingPoint.position.setValue(newPosition);
activeShapePoints.pop();
activeShapePoints.push(newPosition);
// Redraw the shape so it's not dynamic and remove the dynamic shape.
function terminateShape() {
drawShape(activeShapePoints);
viewer.entities.remove(floatingPoint);
viewer.entities.remove(activeShape);
floatingPoint = undefined;
activeShape = undefined;
terminateShape();
}, Cesium.ScreenSpaceEventType.RIGHT_CLICK);
var options = [{
text : 'Draw Lines',
onselect : function() {
terminateShape();
text : 'Points',
terminateShape();
drawingMode = 'point';
text : 'Draw Polygons',
terminateShape();
drawingMode = 'polygon';
I hope this is possible?
Thanks for a great work and support!
BR, Abel Gonzalez
