Dynamic PixelOffset - scaleByDistance, wrong position?
for displaying a billboard/image at at given position I used pixelOffset and calculated this before I added the billboard to the entity.
I also use the function/parameter scaleByDistance, which now causes the billboard-Image to be at the wrong position.
Before scalebydistance
after scalebydistance:
The end of the white line (Polline-entity) should be the beginning of the black-line (in billboard-image)
Is it possible to interact with the scaleBydistance-function or is it possible to use our own function.
Rüdiger
found the answer by myself:
use the pixelOffsetScaleByDistance with the same Parameter as scaleByDistance
Rüdiger
