Dynamic polyline
Hello
I'm trying to change the end of polyline position to current mouse cursor
position on MOUSE_MOVE event (in the same way as in Picking example we change position for a label), but the line changes position very very slowly.
May be I do something wrong?
The code:
    selectionIndicator : false,
    infoBox : false
var scene = viewer.scene;
var handler;
Sandcastle.addDefaultToolbarButton('Show Cartographic Position on Mouse Over', function() {
        label : {
            show : false
    var redLine = viewer.entities.add({
    name : 'Red line on the surface',
    polyline : {
        positions : Cesium.Cartesian3.fromDegreesArray([-75, 35,
                                                        -125, 35]),
        width : 1,
        material : Cesium.Color.RED
    // Mouse over the globe to see the cartographic position
    handler = new Cesium.ScreenSpaceEventHandler(scene.canvas);
    handler.setInputAction(function(movement) {
        var cartesian = viewer.camera.pickEllipsoid(movement.endPosition, scene.globe.ellipsoid);
        if (cartesian) {
            var cartographic = Cesium.Cartographic.fromCartesian(cartesian);
            var longitudeString = Cesium.Math.toDegrees(cartographic.longitude).toFixed(2);
            var latitudeString = Cesium.Math.toDegrees(cartographic.latitude).toFixed(2);
            //entity.position = cartesian;
            //entity.label.show = true;
            //entity.label.text = '(' + longitudeString + ', ' + latitudeString + ')';
            redLine.polyline.positions=Cesium.Cartesian3.fromDegreesArray([-75, 35,
                                                        longitudeString, latitudeString]);
        } else {
            entity.label.show = false;
The line is drawing slowly because it is being drawn asynchronously. To force it to draw synchronously, you can use a CallbackProperty. Here is your updated example:
infoBox : false
var handler;
var pos1 = Cesium.Cartesian3.fromDegrees(-75, 35);
var pos2 = Cesium.Cartesian3.fromDegrees(-75, 35);
function getLinePositions() {
return [pos1, pos2];
name : ‘Red line on the surface’,
polyline : {
positions : new Cesium.CallbackProperty(getLinePositions, false),
width : 1,
if (cartesian) {
pos2 = cartesian;
Hannah
When calling in the context of a class be sure to call it as this.getLinePositions.bind(this)
