Dynamic update primitive?
I create polylineGeometry object,I want dynamic update polylineGeometry width property。
Hi @zyy1987,
Can you please share a code sample to show how you create the polylineGeometry ? I don’t think you can update its width dynamically if you are re using the primitives API
const polyline = new Cesim.PolylineGeometry({
positions: coordinates,
width: polylineWidth,
const geometry = new Cesim.GeometryInstance({
geometry: polyline,
attributes: {
show: new Cesim.ShowGeometryInstanceAttribute(true),
color: currentColor,
const primitive = scene.primitives.add(
new Cesim.Primitive({
geometryInstances: geometry,
appearance: new Cesim.PolylineColorAppearance({
flat: true,
renderState: {
depthTest: { enabled: false },
i want in some scenarios, update the width.
Ok, I don’t think you can only update the width. So what you could do is either remove the instance and create a new one, or you can create several instances with different widths and hide / show the ones with the appropriate width using the getGeometryAttributes method.
let attributes = primitive.getGeometryInstanceAttributes(objId)
if (attributes) {
    attributes.show =
    Cesium.ShowGeometryInstanceAttribute.toValue(false)
this will hide one instance
Thanks for reply!
