Not really a problem I have been tasked with trying to figure out how to allow a user to modify KML entities in a KmlDataSource. For the first step I was trying to determine what is the best way to match the KML entity to a node in the KML document. From previous posts it sounds like I can tie the specific entity to the dataSource, any idea how I can determine which KML document node the entity was derived from?
Once I know the node I was then planning on modifying the KML document and then removing and readding the datasource. (Since the modified KML document would need to be persited).
The last step along the way would be an optimzation to try and change the specific entity without the bulk delete and add.
Users have the capability in google earth and have expressed a need for it in Cesium
Cesium 1-39
