I’m currently having issues getting 3D data to sit on the terrain nicely in Cesium Ion.
I have have some ski routes (lines) which I am trying to lay on the surface as tubes but the data either sits miles above the terrain or as 2D. Ironically, the 3D building (polygons) I’ve got, sit on the surface perfectly using the method I’m using.
Method:
1, Take 2D lines and interpolate to surface (using Esri interpolate shape in ArcGIS Pro) - note, this is the same terrain as I am using in Cesium Ion
Convert lines to tubes in symbology
Convert layer to 3D (geoprocessing tool) and ensure data is EPSG: 3857 with NO DATUM
This all looks really good in Esri.
Use QUICK EXPORT tool to export data to CityGML
Upload CityGML version of data to Cesium Ion
No matter which settings I use from here (whether clamp to terrain, msl or no clamp) the data draws too high or too low
Context:
I am trying to create a workflow for bringing points, lines and polygons from Esri into Cesium so that there is the potential to create 3D mobile applications. At present I can’t find any other method for bringing in geospatial data to Cesium as FME seems to fail with the elevation too (though I can get Esri ArcGIS Pro to get polygons to sit on the surface)
Versions etc:
Currently using Cesium Ion (free) to test which 3D system I should use for a mobile application.
Chrome browse, Win Explorer & Edge
Using Windows 10 64bit on a Microsoft Surface with 32GB of RAM and a NVIdia 1080Ti GPU
