Hello, is there a way to only display the pins when importing KML data? When the icons are placed, the pin and then the name is being displayed, and I want to remove the name part. From my understanding, you could set the label to not be visible in google earth using StyleMap and Style, but the same functionality does not appear to be in Cesium.
Is there another way of removing the name? When there are 30+ pins and names appearing near each other, it's hard to see the map.
Alex
