Ellipse semi/major minor based on mouse position?
Would anyone have an example of drawing an ellipse based on the movement of the mouse they could share?
Appreciate the help!
Take a look at the Picking Sandcastle example for how to handle mouse movement and clicking.
Here’s something along the lines of what you may need, but I imagine you would have more in depth functionality for drawing an ellipse.
var center = Cesium.Cartesian3.fromDegrees(-103.0, 40.0);
var radius = 250000.0;
function getRadius() {
return radius;
var redEllipse = viewer.entities.add({
position: center,
name : ‘Red ellipse on surface’,
ellipse : {
semiMinorAxis : new Cesium.CallbackProperty(getRadius, false),
semiMajorAxis : new Cesium.CallbackProperty(getRadius, false),
material : Cesium.Color.RED.withAlpha(0.5)
var moveHandler = new Cesium.ScreenSpaceEventHandler(viewer.scene.canvas);
moveHandler.setInputAction(function(movement) {
var mousePosition = viewer.camera.pickEllipsoid(movement.endPosition, viewer.scene.globe.ellipsoid);
radius = Cesium.Cartesian3.distance(center, mousePosition);
Thanks Gabby! I was actually more so looking for an example of how to calculate the major/minor based on the current mouse position.
You’ll need the max and min distance from the center.
The following:
var position = viewer.camera.pickEllipsoid(movement.endPosition, viewer.scene.globe.ellipsoid);
Will give you the position of the mouse on the globe.
The rest f the math you should be able to find on a math forum most likely.
