How can I set shader material to polygon entity?
MaterialProperty() doesnt allow me to do that, and I can not set basic Material() to it.
Other question is about rotation.
How can I rotate entity?
I can set initial rotation with ‘orientation’ property, but then it becomes ConstantProperty and wont change.
Next little one: is it possible to move origin of texture? Offset from start. I need to create ‘floating’ layer (Clouds), here is my code:
var pos = Cesium.Cartesian3.fromDegrees(-55.0, 37.0, -6478137.0);
var rad = new Cesium.Cartesian3(6478137.0, 6478137.0, 6478137.0);
window.testEnt = this.viewer.entities.add(
position: pos,
ellipsoid : {
radii : Cesium.Cartesian3.multiplyByScalar(rad, 1.05, rad),
outline : false,
material : new Cesium.ImageMaterialProperty({
image: ‘/assets/textures/fair_clouds_4k.png’,
color: new Cesium.Color(1.0, 1.0, 1.0, 0.4),
transparent: true
May be I’m doing it all wrong.
I need to create cloud layer that will be on top of all other layers and entities (polygons).
Used some dirty hack with negative height for ellipsoid.
My overall aim is to achieve something like this: http://planetmaker.wthr.us/# + clouds.
Atmosphere has inner gradient (done with simple white fog on three.js) and it blacks out on dark side of planet.
Is it possible in cesium?
I can attach screenshots if they are needed.
