I’ve configured an Entity with a path that I want to only show based on my Availability settings that I’ve set.
Here is a Sandcastle example. What I’ve done is added a second before and after in the Viewer relative to the actual availability settings. You will notice that the Point and Model items disappear but the Path does not.
I was able to fix this by simply adding:
entity.isAvailable(time)
to the list of conditionals inside of PathVisualizer.js on line 290. I don’t know what Cesium’s vision is for this but for my needs I need the path to disappear when the entity isn’t available.
If I have multiple Entity’s on the screen with their paths overlapping with time, I only want to show the paths that are currently active.
Cesium 1.58, Win10, Chrome v75.0.3770.142
