Entity rotation using Matrix3
I want to rotate a 3d model.
I have 3x3 Matrix:
<M_00>-0.9999982912233401</M_00>
<M_01>-0.001636319085375301</M_01>
<M_02>-0.0008602425863163225</M_02>
<M_10>-0.001631068695467463</M_10>
<M_11>0.9999802528616577</M_11>
<M_12>-0.00606906089589293</M_12>
<M_20>0.0008701565192966738</M_20>
<M_21>-0.006067647409696231</M_21>
<M_22>-0.9999812130648239</M_22>
A 3x3 matrix, using the <M_ij> tags, where M_ij
denotes the coefficient of the (i+1)th row and the (j+1)th column of the rotation
matrix.
It defines the rotation matrix transforming world
coordinates into camera coordinates (with axes XRightYDown)
Here is my code:
var matrix3 = new Cesium.Matrix3(parseFloat(M_00), parseFloat(M_01), parseFloat(M_02), parseFloat(M_10), parseFloat(M_11), parseFloat(M_12), parseFloat(M_20), parseFloat(M_21), parseFloat(M_22));
var matrix4 = Cesium.Matrix4.fromRotationTranslation(matrix3);
var hpr = Cesium.Transforms.fixedFrameToHeadingPitchRoll(matrix4);
var orientation = Cesium.Transforms.headingPitchRollQuaternion(position, hpr);
position: position,
orientation : orientation,
model : {
uri : url,
scale : 0.6
This does not set the orientation of model. What am I doing wrong?
I think it might be simpler here to just use the quaternion.fromRotationMatrix function directly on your Matrix3. So your code would look something like:
position: position,
orientation: Cesium.Quaternion.fromRotationMatrix(matrix3),
model : {
uri : url,
scale : 0.6
Here’s a running example in Sandcastle.
