Trying to update position of my entity, I did this code:
var res4=0;
var res5=0;
var res6=0;
var res7=0;
var res8=0;
var timer=0;
var entity;
function startup(Cesium) {
'use strict';
//Sandcastle_Begin
Cesium.Ion.defaultAccessToken = 'eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJqdGkiOiJkM2NlYjcwMy1hOTY4LTRiMTgtOWFhMy1hMjZmODA3ZDA3ZTUiLCJpZCI6NTQxMCwic2NvcGVzIjpbImFzciIsImdjIl0sImlhdCI6MTU0MzI3NzIyM30.A8aH7PfgRMThMye_Y77_hfVnxhnGRKGFd_14oZC23pk';
window.setInterval(flightradar('F-GLZJ'),100);
//Sandcastle_Begin
timeline : false,
infoBox : true,
selectionIndicator : false,
shadows : true,
shouldAnimate : true,
terrainProvider: Cesium.createWorldTerrain({requestVertexNormals : true, requestWaterMask: true}),
scene3DOnly: true,
baseLayerPicker: false
var scene = viewer.scene;
scene.globe.enableLighting = true;
scene.globe.depthTestAgainstTerrain = true;
//var layers = scene.imageryLayers;
//var mapOpenWeatherMaps = layers.addImageryProvider(new Cesium.createOpenStreetMapImageryProvider( {
// url: ‘http://tile.openweathermap.org/map/clouds_new’,
// fileExtension: ‘png’ + ‘?appid=d56085bd95e53422bbda70c0fea04ae0’
//mapOpenWeatherMaps.opacity=0.2
// Create entity:
var position = Cesium.Cartesian3.fromDegrees(res5,res4,res7);
var heading = Cesium.Math.toRadians(res6-90);
var pitch = 0;
var roll = 0;
var hpr = new Cesium.HeadingPitchRoll(heading, pitch, roll);
var orientation = Cesium.Transforms.headingPitchRollQuaternion(position, hpr);
entity = viewer.entities.add({
position : position,
orientation : orientation,
model : {
uri : '../../SampleData/models/CesiumAir/Cesium_Air.glb',
minimumPixelSize : 128,
maximumScale : 20000
// Position of the entity:
function flightradar(registration)
timer=timer+1;
// each 100 calling time, get live position from server
if(timer>100)
{var date= new Date();
var res;
var url = 'http://data-live.flightradar24.com/zones/fcgi/feed.js?reg=!’+registration+’&_=’+date;
var doc= new XMLHttpRequest();
doc.onreadystatechange = function(){
if(doc.readyState == XMLHttpRequest.DONE){
res=doc.responseText;//JS.data(doc.responseText);
var res1=res.split("[");
var res2=res1[1];
var res3=res2.split(",");
res4=parseFloat(res3[1]); //latitude_value
res5=parseFloat(res3[2]); // longitude_value
res6=parseFloat(res3[3]); // track_value
res7=parseFloat(res3[4])*0.3048; // altitude_value
res8=parseFloat(res3[5]); // speed_value
//console.log(res4+" “+res5+” “+res6+” “+res7+” "+res8)
doc.open(‘GET’, url, true);
doc.send();
timer=0;
// estimated position following speed & heading until server give position
var vit=res8;
var track=res6;
var lat=res4;
var lon=res5;
var radius = 6370640;
var speed_ms=vit*0.51444;
var distance=speed_ms*0.09;
var δ = Number(distance) / radius; // angular distance in radians
var θ = Number(track)*Math.PI/180;
var φ1 = lat*Math.PI/180;
var λ1 = lon*Math.PI/180;
var sinφ1 = Math.sin(φ1), cosφ1 = Math.cos(φ1);
var sinδ = Math.sin(δ), cosδ = Math.cos(δ);
var sinθ = Math.sin(θ), cosθ = Math.cos(θ);
var sinφ2 = sinφ1*cosδ + cosφ1*sinδ*cosθ;
var φ2 = Math.asin(sinφ2);
var y = sinθ * sinδ * cosφ1;
var x = cosδ - sinφ1 * sinφ2;
var λ2 = λ1 + Math.atan2(y, x);
var newLat =φ2*180/Math.PI;
var newLong=(λ2*180/Math.PI+540)%360-180;
res4=newLat;
res5=newLong;
// final position of the entity
pitch = 0;
roll = 0;
entity.orientation=orientation;
//Sandcastle_End
Sandcastle.finishedLoading();
if (typeof Cesium !== 'undefined') {
startup(Cesium);
} else if (typeof require === 'function') {
require(['Cesium'], startup);
When the entity add is inside the function flightradar with add line viewer.entities.removeAll();, it's working fine but it's flashing because the entity is delete and create many time, that why I want only change the orientation (position + attitude of it).
Then with the code above, I receive error Cannot set property 'orientation' of undefined but the var entity is declare at the top like other variable, could you help me?
