TypeError: Cannot read property ‘length’ of undefined
Got this error when give polyline the new Cesium.PolylineArrowMaterialProperty(Cesium.Color.RED).
No matter give it to the object for PolylineCollection#add or give it to the Polyline returned from the collection#add function.
Is it a bug?
hannah
2
Can you please provide a full code sample that runs in Sandcastle? http://cesiumjs.org/Cesium/Apps/Sandcastle/index.html
That will make it easier for use to reproduce the problem.
Hannah
var collection = new Cesium.PolylineCollection();
var testLine = {
positions : Cesium.Cartesian3.fromDegreesArrayHeights([-75, 43, 500000,
-125, 43, 500000]),
width : 10
viewer.scene.primitives.add(collection);
var line = collection.add(testLine);
line.material = new Cesium.PolylineArrowMaterialProperty(Cesium.Color.PURPLE);
Started from the highlighted place.
在 2016年8月16日星期二 UTC+8下午9:22:47,Hannah Pinkos写道:
hannah
4
You’re seeing the error because you’re creating a polyline using the Primitive API but trying to set the material with a property from the Entity API.
We recommend that you use the entity API for creating polylines. Here is an example: http://cesiumjs.org/Cesium/Apps/Sandcastle/index.html?src=Polyline.html&label=Geometries
Hannah
