Error with Android build
Unity: 2023.2.17f1c1
Installing Android components with unity hub.
I wrote my own script that loads my own graphic source, and partially changed the source code to fit the script.
Here is the log message mentioned in the error:
CMake Deprecation Warning at extern/tidy-html5/CMakeLists.txt:20 (cmake_minimum_required):
Compatibility with CMake < 3.5 will be removed from a future version of
CMake.
Update the VERSION argument value or use a … suffix to tell
CMake that the project does not need compatibility with older versions.
CMake Warning (dev) at extern/tidy-html5/CMakeLists.txt:26 (project):
Policy CMP0048 is not set: project() command manages VERSION variables.
Run “cmake --help-policy CMP0048” for policy details. Use the cmake_policy
command to set the policy and suppress this warning.
The following variable(s) would be set to empty:
PROJECT_VERSION
PROJECT_VERSION_MAJOR
PROJECT_VERSION_MINOR
PROJECT_VERSION_PATCH
This warning is for project developers. Use -Wno-dev to suppress it.
→ TIDY_SO_VERSION = 59. This is an ODD (development) release.
– *** Debug Logging is NOT enabled.
– *** Building support for runtime configuration files.
– *** Only building static library STATIC, version 5.9.14, date 2021.08.17
CMake Deprecation Warning at extern/cesium-native/extern/KTX-Software/cmake/cputypetest.cmake:4 (cmake_minimum_required):
CMake.
Call Stack (most recent call first):
extern/cesium-native/extern/KTX-Software/CMakeLists.txt:23 (include)
– Could NOT find Vulkan (missing: Vulkan_LIBRARY) (found version “1.2.158”)
– Vulkan SDK not found → skipping mkvk target (this is harmless; only needed when re-generating of vulkan headers and dfdutils is required)
– AVX2 backend - OFF
– SSE4.1 backend - OFF
– SSE2 backend - OFF
– NEON backend - ON
– NONE backend - OFF
– NATIVE backend - OFF
– Decompressor - OFF
– Diagnostics - OFF
– Unit tests - OFF
– Could NOT find OpenGL (missing: OPENGL_opengl_LIBRARY OPENGL_glx_LIBRARY OPENGL_INCLUDE_DIR)
– Could NOT find PNG (missing: PNG_LIBRARY PNG_PNG_INCLUDE_DIR)
TIFF is disabled when statically linking.
RY JPEG_INCLUDE_DIR)
– Could NOT find GIF (missing: GIF_LIBRARY GIF_INCLUDE_DIR)
– Performing Test WEBP_HAVE_FLAG_SSE41
– Performing Test WEBP_HAVE_FLAG_SSE41 - Failed
– Performing Test HAS_COMPILE_FLAG
– Performing Test HAS_COMPILE_FLAG - Success
– Performing Test WEBP_HAVE_FLAG_SSE2
– Performing Test WEBP_HAVE_FLAG_SSE2 - Failed
– Performing Test WEBP_HAVE_FLAG_MIPS32
– Performing Test WEBP_HAVE_FLAG_MIPS32 - Failed
– Performing Test WEBP_HAVE_FLAG_MIPS_DSP_R2
– Performing Test WEBP_HAVE_FLAG_MIPS_DSP_R2 - Failed
– Performing Test WEBP_HAVE_FLAG_NEON
– Performing Test WEBP_HAVE_FLAG_NEON - Success
– Performing Test WEBP_HAVE_FLAG_MSA
– Performing Test WEBP_HAVE_FLAG_MSA - Failed
CMake Deprecation Warning at extern/cesium-native/extern/uriparser/CMakeLists.txt:37 (cmake_minimum_required):
CMake.
– Configuration
– Build type … Debug
– Shared libraries … OFF
– Compiler flags
– C … -DANDROID -fdata-sections -ffunction-sections -funwind-tables -fstack-protector-strong -no-canonical-prefixes -D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security -fexceptions -fvisibility=hidden
– C++ … -DANDROID -fdata-sections -ffunction-sections -funwind-tables -fstack-protector-strong -no-canonical-prefixes -D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security -fexceptions -frtti -stdlib=libc++ -fvisibility=hidden
– Linker flags
– Executable … -Wl,–build-id=sha1 -Wl,–no-rosegment -Wl,–fatal-warnings -Qunused-arguments -Wl,–no-undefined -Wl,–gc-sections
– Module … -Wl,–build-id=sha1 -Wl,–no-rosegment -Wl,–fatal-warnings -Qunused-arguments -Wl,–no-undefined
– Shared … -Wl,–build-id=sha1 -Wl,–no-rosegment -Wl,–fatal-warnings -Qunused-arguments -Wl,–no-undefined
– Paths
– Prefix … E:/UnityProject/cesium-unity-samples-1.9.0/Packages/com.cesium.unity/Plugins/Android/arm64
– qhelpgenerator …
– Features
– Code for char * … ON
– Code for wchar_t * … ON
– Tools … OFF
– Test suite … OFF
– Documentation … OFF
– Continue with
– make
– make test
– sudo make install
CMake Warning (dev) at extern/cesium-native/extern/draco/CMakeLists.txt:40 (include):
Policy CMP0148 is not set: The FindPythonInterp and FindPythonLibs modules
are removed. Run “cmake --help-policy CMP0148” for policy details. Use
the cmake_policy command to set the policy and suppress this warning.
— Running combined CXX flags test, flags: -Wno-implicit-const-int-float-conversion
— Passed combined CXX flags test
CMake Deprecation Warning at extern/cesium-native/extern/meshoptimizer/CMakeLists.txt:1 (cmake_minimum_required):
CMake.
CMake Deprecation Warning at extern/cesium-native/extern/glm/CMakeLists.txt:1 (cmake_minimum_required):
CMake.
CMake Deprecation Warning at extern/cesium-native/extern/glm/CMakeLists.txt:2 (cmake_policy):
CMake.
CMake Deprecation Warning at extern/cesium-native/extern/asyncplusplus/CMakeLists.txt:21 (cmake_minimum_required):
CMake.
– Build spdlog: 1.10.0
– Build type: Debug
– Project ‘expected_lite’, package ‘expected-lite’ version: ‘0.6.2’
CMake Deprecation Warning at build-Android-arm64/extern/cesium-native/extern/zlib-src/CMakeLists.txt:1 (cmake_minimum_required):
CMake.
CMake Warning (dev) at build-Android-arm64/extern/cesium-native/extern/zlib-src/CMakeLists.txt:4 (project):
PROJECT_VERSION
– Renaming
– E:/UnityProject/cesium-unity-samples-1.9.0/Packages/com.cesium.unity/native~/build-Android-arm64/extern/cesium-native/extern/zlib-src/zconf.h
– to ‘zconf.h.included’ because this file is included with zlib
– but CMake generates it automatically in the build directory.
– Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
– Configuring done (21.5s)
CMake Warning in extern/cesium-native/extern/draco/CMakeLists.txt:
The object file directory
E:/UnityProject/cesium-unity-samples-1.9.0/Packages/com.cesium.unity/native~/build-Android-arm64/extern/cesium-native/extern/draco/CMakeFiles/draco_compression_attributes_dec.dir/
has 179 characters. The maximum full path to an object file is 250
characters (see CMAKE_OBJECT_PATH_MAX). Object file
src/draco/compression/attributes/sequential_integer_attribute_decoder.cc.o
cannot be safely placed under this directory. The build may not work
correctly.
E:/UnityProject/cesium-unity-samples-1.9.0/Packages/com.cesium.unity/native~/build-Android-arm64/extern/cesium-native/extern/draco/CMakeFiles/draco_compression_attributes_enc.dir/
src/draco/compression/attributes/sequential_attribute_encoders_controller.cc.o
correctly.
E:/UnityProject/cesium-unity-samples-1.9.0/Packages/com.cesium.unity/native~/build-Android-arm64/extern/cesium-native/extern/draco/CMakeFiles/draco_compression_attributes_pred_schemes_enc.dir/
has 192 characters. The maximum full path to an object file is 250
4903a2f1d67bacb7cbad22462a10a95f/prediction_scheme_encoder_factory.cc.o
correctly.
– Generating done (6.0s)
– Build files have been written to: E:/UnityProject/cesium-unity-samples-1.9.0/Packages/com.cesium.unity/native~/build-Android-arm64
[ 0%] Built target libjpeg-turbo
[ 0%] Built target sqlite3
[ 1%] Built target csprng
[ 1%] Built target cpufeatures
[ 1%] Built target tinyxml2
[ 1%] Built target modp_b64
[ 1%] Building CXX object extern/cesium-native/extern/draco/CMakeFiles/draco_compression_attributes_pred_schemes_enc.dir/4903a2f1d67bacb7cbad22462a10a95f/prediction_scheme_encoder_factory.cc.o
[ 1%] Built target draco_animation
[0x7FFEE83D0BD0] ANOMALY: meaningless REX prefix used
[0x7FFF21895C90] ANOMALY: meaningless REX prefix used
[0x7FFEE83CE890] ANOMALY: meaningless REX prefix used
[ 4%] Built target meshoptimizer
[ 4%] Built target draco_compression_attributes_pred_schemes_enc
[ 4%] Built target sharpyuv
[ 4%] Built target Async++
[ 4%] Built target draco_compression_decode
[ 6%] Built target zlibstatic
[ 9%] Built target uriparser
[ 10%] Built target webputilsdecode
[ 10%] Built target draco_compression_entropy
[ 10%] Built target draco_metadata_dec
[ 10%] Built target draco_attributes
[ 10%] Built target draco_compression_options
[ 12%] Built target webputils
[ 13%] Built target draco_core
[ 14%] Built target draco_compression_point_cloud_dec
[ 14%] Built target draco_metadata_enc
[ 14%] Built target draco_animation_dec
[ 14%] Built target draco_compression_point_cloud_enc
[ 14%] Built target draco_animation_enc
[ 14%] Built target draco_point_cloud
[ 16%] Built target draco_compression_bit_coders
[ 20%] Built target ktx_read
[ 21%] Built target draco_metadata
[ 21%] Built target draco_compression_encode
[ 22%] Built target draco_points_dec
[ 22%] Built target draco_points_enc
[ 25%] Built target webpdspdecode
[ 27%] Built target spdlog
[ 27%] Built target draco_compression_mesh_enc
[ 28%] Built target draco_mesh
[ 29%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/access.c.o
[ 29%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/attrs.c.o
[ 29%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/istack.c.o
[ 29%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/parser.c.o
[ 29%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/tags.c.o
[ 29%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/entities.c.o
[ 29%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/lexer.c.o
[ 29%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/pprint.c.o
[ 31%] Built target draco_compression_mesh_dec
[ 32%] Built target webpdecode
[ 32%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/charsets.c.o
[ 32%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/clean.c.o
[ 33%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/message.c.o
[ 33%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/config.c.o
[ 33%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/alloc.c.o
E:/UnityProject/cesium-unity-samples-1.9.0/Packages/com.cesium.unity/native~/extern/tidy-html5/src/parser.c:5971:9: warning: misleading indentation; statement is not part of the previous ‘if’ [-Wmisleading-indentation]
return isBlank;
E:/UnityProject/cesium-unity-samples-1.9.0/Packages/com.cesium.unity/native~/extern/tidy-html5/src/parser.c:5967:5: note: previous statement is here
if ( isBlank )
[ 33%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/attrdict.c.o
[ 33%] Built target webpdecoder
1 warning generated.
[ 33%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/buffio.c.o
[ 33%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/fileio.c.o
[ 33%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/streamio.c.o
[ 33%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/tagask.c.o
[ 33%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/tmbstr.c.o
[ 35%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/utf8.c.o
[ 35%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/tidylib.c.o
[ 35%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/mappedio.c.o
[ 35%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/gdoc.c.o
[ 35%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/language.c.o
[ 35%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/messageobj.c.o
[ 35%] Building C object extern/tidy-html5/CMakeFiles/tidy-static.dir/src/sprtf.c.o
[ 35%] Linking C static library libtidy.a
[ 35%] Built target tidy-static
[ 37%] Built target webpdsp
[ 39%] Built target draco_compression_attributes_enc
[ 41%] Built target webpencode
[ 44%] Built target s2geometry
[ 45%] Built target draco_io
[ 47%] Built target draco_compression_attributes_dec
[ 48%] Built target CesiumUtility
make[2]: *** No rule to make target ‘extern/cesium-native/extern/draco/CMakeFiles/draco_compression_attributes_pred_schemes_enc.dir/4903a2f1d67bacb7cbad22462a10a95f/prediction_scheme_encoder_factory.cc.o’, needed by ‘extern/cesium-native/extern/draco/libdracod.a’. Stop.
make[1]: *** [CMakeFiles/Makefile2:2359: extern/cesium-native/extern/draco/CMakeFiles/draco_static.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs…
[ 48%] Building CXX object extern/cesium-native/CesiumAsync/CMakeFiles/CesiumAsync.dir/src/AsyncSystem.cpp.o
[ 50%] Building CXX object extern/cesium-native/CesiumGeometry/CMakeFiles/CesiumGeometry.dir/src/Availability.cpp.o
[ 50%] Building CXX object extern/cesium-native/CesiumAsync/CMakeFiles/CesiumAsync.dir/src/CachingAssetAccessor.cpp.o
[ 50%] Building CXX object extern/cesium-native/CesiumGltf/CMakeFiles/CesiumGltf.dir/src/Accessor.cpp.o
[ 50%] Building CXX object extern/cesium-native/CesiumGeometry/CMakeFiles/CesiumGeometry.dir/src/BoundingSphere.cpp.o
[ 50%] Building CXX object extern/cesium-native/CesiumJsonReader/CMakeFiles/CesiumJsonReader.dir/src/BoolJsonHandler.cpp.o
[ 50%] Building CXX object extern/cesium-native/CesiumAsync/CMakeFiles/CesiumAsync.dir/src/GunzipAssetAccessor.cpp.o
[ 50%] Building CXX object extern/cesium-native/CesiumGltf/CMakeFiles/CesiumGltf.dir/src/AccessorUtility.cpp.o
[ 52%] Building CXX object extern/cesium-native/CesiumJsonReader/CMakeFiles/CesiumJsonReader.dir/src/DoubleJsonHandler.cpp.o
[ 52%] Building CXX object extern/cesium-native/Cesium3DTiles/CMakeFiles/Cesium3DTiles.dir/src/Library.cpp.o
[ 52%] Building CXX object extern/cesium-native/CesiumGeometry/CMakeFiles/CesiumGeometry.dir/src/CullingVolume.cpp.o
[ 52%] Building CXX object extern/cesium-native/CesiumGltf/CMakeFiles/CesiumGltf.dir/src/FeatureIdTextureView.cpp.o
[ 52%] Building CXX object extern/cesium-native/Cesium3DTiles/CMakeFiles/Cesium3DTiles.dir/src/MetadataQuery.cpp.o
[ 52%] Building CXX object extern/cesium-native/CesiumJsonReader/CMakeFiles/CesiumJsonReader.dir/src/ExtensibleObjectJsonHandler.cpp.o
[ 52%] Building CXX object extern/cesium-native/CesiumAsync/CMakeFiles/CesiumAsync.dir/src/HttpHeaders.cpp.o
[ 52%] Building CXX object extern/cesium-native/CesiumJsonReader/CMakeFiles/CesiumJsonReader.dir/src/ExtensionsJsonHandler.cpp.o
[ 52%] Building CXX object extern/cesium-native/CesiumGltf/CMakeFiles/CesiumGltf.dir/src/KhrTextureTransform.cpp.o
[ 52%] Building CXX object extern/cesium-native/CesiumGeometry/CMakeFiles/CesiumGeometry.dir/src/IntersectionTests.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumAsync/CMakeFiles/CesiumAsync.dir/src/InternalTimegm.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumAsync/CMakeFiles/CesiumAsync.dir/src/QueuedScheduler.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumGeometry/CMakeFiles/CesiumGeometry.dir/src/OctreeAvailability.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumJsonReader/CMakeFiles/CesiumJsonReader.dir/src/IgnoreValueJsonHandler.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumGltf/CMakeFiles/CesiumGltf.dir/src/Ktx2TranscodeTargets.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumGeometry/CMakeFiles/CesiumGeometry.dir/src/OctreeTilingScheme.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumGltf/CMakeFiles/CesiumGltf.dir/src/Model.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumJsonReader/CMakeFiles/CesiumJsonReader.dir/src/JsonHandler.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumAsync/CMakeFiles/CesiumAsync.dir/src/ResponseCacheControl.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumGltf/CMakeFiles/CesiumGltf.dir/src/PropertyAttributePropertyView.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumAsync/CMakeFiles/CesiumAsync.dir/src/SqliteCache.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumGeometry/CMakeFiles/CesiumGeometry.dir/src/OrientedBoundingBox.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumJsonReader/CMakeFiles/CesiumJsonReader.dir/src/JsonObjectJsonHandler.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumAsync/CMakeFiles/CesiumAsync.dir/src/TaskScheduler.cpp.o
[ 54%] Linking CXX static library libCesium3DTilesd.a
[ 54%] Building CXX object extern/cesium-native/CesiumGeometry/CMakeFiles/CesiumGeometry.dir/src/Plane.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumGltf/CMakeFiles/CesiumGltf.dir/src/PropertyAttributeView.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumAsync/CMakeFiles/CesiumAsync.dir/src/ThreadPool.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumJsonReader/CMakeFiles/CesiumJsonReader.dir/src/JsonReader.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumGeometry/CMakeFiles/CesiumGeometry.dir/src/QuadtreeAvailability.cpp.o
[ 54%] Building CXX object extern/cesium-native/CesiumGltf/CMakeFiles/CesiumGltf.dir/src/PropertyTablePropertyView.cpp.o
[ 55%] Building CXX object extern/cesium-native/CesiumGeometry/CMakeFiles/CesiumGeometry.dir/src/QuadtreeRectangleAvailability.cpp.o
[ 55%] Building CXX object extern/cesium-native/CesiumJsonReader/CMakeFiles/CesiumJsonReader.dir/src/JsonReaderOptions.cpp.o
[ 55%] Building CXX object extern/cesium-native/CesiumGltf/CMakeFiles/CesiumGltf.dir/src/PropertyTableView.cpp.o
[ 55%] Building CXX object extern/cesium-native/CesiumGltf/CMakeFiles/CesiumGltf.dir/src/PropertyTexturePropertyView.cpp.o
[ 55%] Building CXX object extern/cesium-native/CesiumGeometry/CMakeFiles/CesiumGeometry.dir/src/QuadtreeTileID.cpp.o
[ 55%] Building CXX object extern/cesium-native/CesiumJsonReader/CMakeFiles/CesiumJsonReader.dir/src/ObjectJsonHandler.cpp.o
[ 55%] Building CXX object extern/cesium-native/CesiumGltf/CMakeFiles/CesiumGltf.dir/src/PropertyTextureView.cpp.o
[ 55%] Building CXX object extern/cesium-native/CesiumGeometry/CMakeFiles/CesiumGeometry.dir/src/QuadtreeTilingScheme.cpp.o
[ 55%] Built target Cesium3DTiles
[ 55%] Building CXX object extern/cesium-native/CesiumJsonReader/CMakeFiles/CesiumJsonReader.dir/src/StringJsonHandler.cpp.o
[ 56%] Building CXX object extern/cesium-native/CesiumGltf/CMakeFiles/CesiumGltf.dir/src/PropertyType.cpp.o
[ 56%] Building CXX object extern/cesium-native/CesiumGeometry/CMakeFiles/CesiumGeometry.dir/src/Ray.cpp.o
[ 56%] Building CXX object extern/cesium-native/CesiumGltf/CMakeFiles/CesiumGltf.dir/src/PropertyView.cpp.o
[ 56%] Building CXX object extern/cesium-native/CesiumGltf/CMakeFiles/CesiumGltf.dir/src/SamplerUtility.cpp.o
[ 56%] Building CXX object extern/cesium-native/CesiumGltf/CMakeFiles/CesiumGltf.dir/src/TextureView.cpp.o
[ 56%] Building CXX object extern/cesium-native/CesiumGeometry/CMakeFiles/CesiumGeometry.dir/src/Rectangle.cpp.o
[ 56%] Building CXX object extern/cesium-native/CesiumGeometry/CMakeFiles/CesiumGeometry.dir/src/Transforms.cpp.o
[ 56%] Building CXX object extern/cesium-native/CesiumGeometry/CMakeFiles/CesiumGeometry.dir/src/clipTriangleAtAxisAlignedThreshold.cpp.o
[ 56%] Linking CXX static library libCesiumAsyncd.a
[ 58%] Linking CXX static library libCesiumJsonReaderd.a
[ 58%] Linking CXX static library libCesiumGeometryd.a
[ 58%] Built target CesiumAsync
[ 58%] Built target CesiumJsonReader
[ 58%] Linking CXX static library libCesiumGltfd.a
[ 58%] Built target CesiumGeometry
[ 58%] Built target CesiumGltf
make: *** [Makefile:156: all] Error 2
It’s worth noting that some of the prompts in the logs are error messages prompted by my computer using the command line and should be ignored, the messages are as follows:
