I try to use UrlTemplateImageryProvider to load a map service with custom projection hosted by ArcGIS Server. And I met CORS problem.
The service is not hosted in my local device. But I can load the map service by using ArcGIS JavaScript API and Openlayers in my localhost.
var imageryLayers = viewer.imageryLayers;
imageryLayers.addImageryProvider(new Cesium.UrlTemplateImageryProvider({
url : ‘http://remote IP address:8080/rest/services/shmap/MapServer/tile/{newz}/{newy}/{newx}’,
customTags : {
newz: function(imageryProvider, x, y, level) {
return level-9;
newy: function(imageryProvider, x, y, level) {
return y-165* (1 << (level-9));
newx: function(imageryProvider, x, y, level) {
return x-855* (1 << (level-9));
tilingScheme:new Cesium.GeographicTilingScheme()
I want to figure out it is a client side (Cesium) problem or a server side problem (ArcGIS Server).
Cesium 1.46.1
Windows 10
Chrome 67.0.3396.99
