The menu ends up behind my Legend. How do I get the menu to always be on top?
Hi @tzgardner,
I would try adding CSS to the cesium-baseLayerPicker-dropDown class, in this case adjusting the z-index.
I did a search for cesium-baseLayerPicker-dropDown as you can see from screenshot above.
I tried adjusting each BaseLayerPicker.css files from the list above. No changes seem to have any effect on any formatting. I not only adjusted the z-index but I also tried adjusting max-height. Nothing I changed seemed to have any effect at all.
Where exactly do I need to add the z-index changes?
@tzgardner You can override existing CSS rules in a CSS file external to CesiumJS. You can also add the !important keyword to ensure it overrides anything else:
.cesium-baseLayerPicker-dropDown {
z-index: -100 !important;
That did it! Thanks!
