Hi there,
I have geojson files of buildings exported through Qgis from shapefiles..
its code seems fine to me but it just does not load!
can someone help me out...
it can go directly in the hello world example with the following code:
var dataSource = Cesium.GeoJsonDataSource.load('geovogatic/test.geojson');
and the sample geojson code is as follows:
"type": "FeatureCollection",
"crs": { "type": "name", "properties": { "name": "urn:ogc:def:crs:EPSG::3857" } },
"features": [
{ "type": "Feature", "properties": { "Layer": "0", "SubClasses": "AcDbEntity:AcDbHatch", "ExtendedEntity": null, "Linetype": null, "EntityHandle": "20001", "Text": "SOLID" }, "geometry": { "type": "Polygon", "coordinates": [ [ [ 268271.634355565009173, 2705856.544927590060979 ], [ 268272.490466132003348, 2705858.804040470160544 ], [ 268272.490466132003348, 2705858.804040470160544 ], [ 268271.634355565009173, 2705856.544927590060979 ], [ 268271.634355565009173, 2705856.544927590060979 ] ] ] } },
{ "type": "Feature", "properties": { "Layer": "0", "SubClasses": "AcDbEntity:AcDbHatch", "ExtendedEntity": null, "Linetype": null, "EntityHandle": "20002", "Text": "SOLID" }, "geometry": { "type": "Polygon", "coordinates": [ [ [ 268275.632829423004296, 2705855.029670979827642 ], [ 268271.634355565009173, 2705856.544927590060979 ], [ 268271.634355565009173, 2705856.544927590060979 ], [ 268275.632829423004296, 2705855.029670979827642 ], [ 268275.632829423004296, 2705855.029670979827642 ] ] ] } },
{ "type": "Feature", "properties": { "Layer": "0", "SubClasses": "AcDbEntity:AcDbHatch", "ExtendedEntity": null, "Linetype": null, "EntityHandle": "20003", "Text": "SOLID" }, "geometry": { "type": "Polygon", "coordinates": [ [ [ 268275.446774897980504, 2705854.538708500098437 ], [ 268275.446774897980504, 2705854.538708500098437 ], [ 268275.632829423004296, 2705855.029670979827642 ], [ 268275.632829423004296, 2705855.029670979827642 ], [ 268275.446774897980504, 2705854.538708500098437 ] ] ] } },
{ "type": "Feature", "properties": { "Layer": "0", "SubClasses": "AcDbEntity:AcDbHatch", "ExtendedEntity": null, "Linetype": null, "EntityHandle": "20004", "Text": "SOLID" }, "geometry": { "type": "Polygon", "coordinates": [ [ [ 268278.13373798399698, 2705853.520462090149522 ], [ 268275.446774897980504, 2705854.538708500098437 ], [ 268275.446774897980504, 2705854.538708500098437 ], [ 268278.13373798399698, 2705853.520462090149522 ], [ 268278.13373798399698, 2705853.520462090149522 ] ] ] } },
{ "type": "Feature", "properties": { "Layer": "0", "SubClasses": "AcDbEntity:AcDbHatch", "ExtendedEntity": null, "Linetype": null, "EntityHandle": "20005", "Text": "SOLID" }, "geometry": { "type": "Polygon", "coordinates": [ [ [ 268278.324060110026039, 2705854.021603310015053 ], [ 268278.13373798399698, 2705853.520462090149522 ], [ 268278.13373798399698, 2705853.520462090149522 ], [ 268278.324060110026039, 2705854.021603310015053 ], [ 268278.324060110026039, 2705854.021603310015053 ] ] ] } },
{ "type": "Feature", "properties": { "Layer": "0", "SubClasses": "AcDbEntity:AcDbHatch", "ExtendedEntity": null, "Linetype": null, "EntityHandle": "20006", "Text": "SOLID" }, "geometry": { "type": "Polygon", "coordinates": [ [ [ 268282.453285931027494, 2705852.456797100137919 ], [ 268278.324060110026039, 2705854.021603310015053 ], [ 268278.324060110026039, 2705854.021603310015053 ], [ 268282.453285931027494, 2705852.456797100137919 ], [ 268282.453285931027494, 2705852.456797100137919 ] ] ] } },
Thank you
