Hi all,
I’m looking to this example:
http://analyticalgraphicsinc.github.io/cesium-google-earth-examples/examples/groundAlt.html
Is there some way to access to the service that gives the height of a certain point in a java client without using Cesium?
Thanks in advance
Regards
Cris
I have also noticed that there is a difference of more or less 50m between the ground altitude using Cesium and using Google Earth.
Why is there so much difference?
Cris
hannah
May 12, 2016, 12:19pm
3
Hello Cris,
Using this method, the accuracy of the height is based on the zoom level of the camera
For a more consistent result, you can use the Ceisum.SampleTerrain function to query the terrain http://cesiumjs.org/Cesium/Build/Documentation/sampleTerrain.html
If you use a higher level, the height of the point returned will be more accurate.
Hannah
