Adding polygons via geojson, did some edits to the clock/viewer and now globe is frozen, but I see that time is passing. Can’t seem to undo my error.
// var viewer = new Cesium.Viewer(‘cesiumContainer’, { infoBox : false });
var clock = new Cesium.Clock({
startTime : Cesium.JulianDate.fromIso8601(‘1990-01-01’),
currentTime : Cesium.JulianDate.fromIso8601(‘1990-01-01’),
stopTime : Cesium.JulianDate.fromIso8601(‘2018-12-31’),
clockRange : Cesium.ClockRange.LOOP_STOP, // loop when we hit the end time
clockStep : Cesium.ClockStep.SYSTEM_CLOCK_MULTIPLIER,
multiplier : 4000, // how much time to advance each tick
shouldAnimate : true // Animation on by default
clockViewModel : new Cesium.ClockViewModel(clock)
var promise = Cesium.GeoJsonDataSource.load(‘/static/data/globe2.geo.json’);
promise.then(function(dataSource) {
//Get the array of entities
console.log("Total Entities: " + entities.length);
for (var i = 0; i < entities.length; i++) {
var entity = entities[i];
entity.polygon.extrudedHeight = entity.properties.TraffickingStats._value.Total * 1000;
objColor = entity.properties.color._value;
entity.polygon.material = Cesium.Color.fromCssColorString(objColor).withAlpha(0.5)
entity.polygon.outline = false;
// entity.availability = Cesium.TimeInterval.fromIso8601(entity.properties.Interval._value);
I am rendering a lot of geometries, maybe Ill serve the jsons piecewise, but it was working before.
Using Cesium 1.52 in Chrome, Thanks so much for your help!
exampleglobe.geo.json (60.2 KB)
