Gradient for PolylineGraphics
Hi everyone. I need to make a gradient for PolylineGraphics. If its height is up to 1000, the color of the polyline segment is blue, if it is up to 3000 - yellow, if it is over 3000 - red. How to do it?
let entity = new Entity({
					icon_type: item.icon_type,
					position: Cartesian3.fromDegrees(
						item!.L * Math.DEGREES_PER_RADIAN,
						item!.B * Math.DEGREES_PER_RADIAN,
						item!.H
					orientation: new CallbackProperty(() => {
						return orientation;
					}, false),
                           entity.polyline = new PolylineGraphics({
					positions: new CallbackProperty(() => {
						let points = WallAirData!.get(item!.UID)
						let arrayHeights = [
							points[points.length - 3],
							points[points.length - 2],
							points[points.length - 1],
							0
						return Cartesian3.fromDegreesArrayHeights(arrayHeights)
					}, false),
					show: storeProjectionStatusAll
Hi there,
This would be possible by using fabric and a custom shader code, but that will require writing some lower-level graphic code.
Can you explain your use case a bit? There may be an alternative approach.
Hi, Gabby! Here’s my code:
entity.polyline = {
						let points = WallData!.get(item!.ID)
							0
					}, false),
					show: oldEntity.polyline?.show?.getValue(),
