Greetings everyone, I’m a little confused on how to do this right. My current code works, but I doubt it is the most efficient way to do it. Below you’ll see a similar setup to the Sand Castle demo for Cesium where the user is allowed to draw a line. I’ve set it up this scenario with similar variable names to avoid confusion as much as I can.
Anyway, once an event occurs I’m getting Cartesian values using “pickEllipsoid”, but since the client needs the elevation to be set at a default (this is for aircraft) I’m then having to convert it to latitude and longitude only to convert those values back into Cartesian alongside a custom elevation of “30000”.
Is there anyway to just feed pickEllipsoid a default elevation in order to skip one of these steps? I’m feel sure I’ve just missed something in the documentation.
handler.setInputAction(function(e) {
let mousePosition = e.position
let ellipsoid = viewer.scene.globe.ellipsoid
// Converts to cartesian3
let earthPosition = viewer.camera.pickEllipsoid(mousePosition, ellipsoid)
if (Cesium.defined(earthPosition)) {
// Converts cartesian3 to latitude and longitude
let cartographic = ellipsoid.cartesianToCartographic(earthPosition)
let long = Cesium.Math.toDegrees(cartographic.longitude)
let lat = Cesium.Math.toDegrees(cartographic.latitude)
// Converts back to cartesian3 along with custom elevation
let coords = Cesium.Cartesian3.fromDegrees(long, lat, 30000)
if (activeShapePoints.length === 0) {
floatingPoint = createPoint(coords)
activeShapePoints.push(coords)
let dynamicPositions = new Cesium.CallbackProperty(function (time, result) {
return activeShapePoints
}, false)
activeShape = drawShape(dynamicPositions, 5, cString)
createPoint(coords)
}, Cesium.ScreenSpaceEventType.LEFT_CLICK)
handler.setInputAction(function(event) {
if (Cesium.defined(floatingPoint)) {
console.log(event.endPosition)
let earthPosition = viewer.camera.pickEllipsoid(event.endPosition, ellipsoid)
// Converts cartesian to latitude and longitude
floatingPoint.position.setValue(coords)
activeShapePoints.pop()
This is needed due to my client needing to the ability to draw routes for aircraft.
**Cesium **1.55.0
**Browser: Google Chrome **Version 75.0.3770.90
