Help adjusting CesiumJS clock to Chile timezone (UTC-3) in React
Hey guys,
I need some help changing the time displayed by the CesiumJS clock.
I’m using React 19.1.0 and Cesium 1.130.0.
Basically, I have a Viewer component that passes the onReady prop to a function called handleViewerReady, where I try to adjust the time zone to Chile (UTC-3).
Here’s a simplified version of my code:
          <Viewer
            ref={viewerRef}
            full
            baseLayerPicker={false}
            geocoder={false}
            navigationInstructionsInitiallyVisible={false}
            selectionIndicator={true}
            infoBox={false}
            animation={timeLine}
            timeline={timeLine}
            homeButton={false}
            navigationHelpButton={false}
            shouldAnimate={true}
            onReady={handleViewerReady}
And here’s the function:
  function handleViewerReady(viewer) {
    const now = new Date();
    const start = JulianDate.addHours(JulianDate.fromDate(now), -3);
    const stop = JulianDate.addHours(start, 1, new JulianDate());
    viewer.clock.startTime = start;
    viewer.clock.currentTime = start;
    viewer.clock.stopTime = stop;
    viewer.clock.clockRange = ClockRange.LOOP_STOP;
    viewer.clock.clockStep = ClockStep.SYSTEM_CLOCK;
    viewer.clock.multiplier = 1;
    viewer.clock.shouldAnimate = true;
    viewer.timeline.zoomTo(start, stop);
This function gets the current date and tries to shift it to UTC-3, but the time shown in Cesium doesn’t seem to match what I expect.
I’m not sure if this is the right way to handle local time zones in Cesium, or if I need to use a different approach with JulianDate or Clock.
Any ideas on how to correctly set the clock to show Chile’s local time (UTC-3)?
Thanks in advance!
Hi @MatiasDevCL, have you looked at AnimationViewModel.defaultTimeFormatter? The usual defaultTimeFormatter reports UTC time, but you can over-ride the function.
I tried a very simple version, formatting the timestring in the device’s locale format, in this Sandcastle.
