I try to create a circle outline geometry.(primitive)
In my computer there was an error :"Appearance/Geometry mismatch etc.’ ".
I use cesium version 1.70.
So I loaded the code into sandcastle, and there are no errors, but also
there is no any circle outline geometry.
Please help!
Thanks in advance.
P.s: the outline circle need to be drawn in Israel.
Just now, i converted this code to typescript.
And what i see? That CircleOutlineGeometry inside Cesium.d.ts doesnt have a vertexformat.
So i removed it and still see the error:
DeveloperError: Appearance/Geometry mismatch. The appearance requires vertex shader attribute input 'compressedAttribute', ehich was not computed as part of the geometry. Use the appearance's vertexFormat property when constructingthe geometry.
