How bigger the size of .gltf model can handle cesium?
If a file over 300mb, would it not effect the processing time? If so, what are good spec for a system to handle such files.
Thanks
Thanks
Hi Umar,
We are working on 3D Tiles, a spatial data structure that contains glTF tiles, to stream massive models like this, see https://github.com/AnalyticalGraphicsInc/3d-tiles
You could also try to run a decimation algorithm on the geometry and/or use lower resolution textures to load this as a single glTF model.
Patrick
