When left-clicking on points on the Cesium globe, I noticed that a green selector box appears surrounding the entity. Is there a way to change this selector? Are there other selectors I can choose from/can I make a custom selector?
Sorry, I replied under the wrong post. I was referring to the pulsating solution you created using a SampledProperty object on this StackOverflow question: https://stackoverflow.com/questions/42842607/cesiumjs-points-and-css-keyframe-animation. Do you know if it's possible to set the number of times the point pulsates, rather than have it pulse infinitely?
If I do that, though, it will only pulsate once and then stop. Ideally, I would like for the pulse to continue a certain amount of times before stopping. Is this possible?
That worked! Thank you for your help. Do you guys, by any chance, know if it’s possible for the pulse to run on it’s own standalone clock, rather than having to alter the viewer clock? Is it possible to have multiple clock instances running?
I found this post, giving an example on how to create more clocks in addition to the main viewer clock. I am just confused on how to get the SampledProperty to follow the newly created clock rather than the viewer clock.
