i tried setting height = -30 but when the page loads it stays above the ground
You initialize the height and add a listener for it but the listener doesn’t execute at the first time. Maybe it is due to the feature of knockout itself (not sure, I don’t know about knockout)? So why not set the height explicitly at the first time?
i tried setting the initial height to -30 but it still doesn’t work
oh i found it, i put `
var heightOffset = -30.0;
tileset.readyPromise.then(function(tileset) {
var boundingSphere = tileset.boundingSphere;
viewer.camera.viewBoundingSphere(boundingSphere, new Cesium.HeadingPitchRange(0, -2.0, 0));
viewer.camera.lookAtTransform(Cesium.Matrix4.IDENTITY);
// Position tileset
var cartographic = Cesium.Cartographic.fromCartesian(boundingSphere.center);
var surface = Cesium.Cartesian3.fromRadians(cartographic.longitude, cartographic.latitude, 0.0);
var offset = Cesium.Cartesian3.fromRadians(cartographic.longitude, cartographic.latitude, heightOffset);
var translation = Cesium.Cartesian3.subtract(offset, surface, new Cesium.Cartesian3());
tileset.modelMatrix = Cesium.Matrix4.fromTranslation(translation);
console.log(tileset.modelMatrix);
Yes that is what I mean, you may need to manually trigger the listener or call it directly.
tileset.readyPromise.then(() => (viewModel1.height = -30))
// Or
tileset.readyPromise.then(() => listener())
thank you very much!!
