I need to add capability to my Cesium app to drag-and-drop images(.png, .jpg, etc) onto it. Then, when the drop happens, I need to create a billboard with that image.
At first, I thought that the way to do it is to use Cesium.viewerDragDropMixin.
However it doesn't seem to have a way to specify function that is called when drop happens. I looked at the code for the Cesium.viewerDragDropMixinand saw a function handleDrop there which is specific to Czml.
When I tried to write my own mixin, using Cesium.viewerDragDropMixin as an example, Cesium crashed with message "Uncaught DeveloperError: mixin is required.".
So the questions I have are:
1. what is a proper way to implement Drag-andDrop
2. if I can use Cesium.viewerDragDropMixin, how do I specify function to process the drop?
3. If the proper way is to implement my own mixin, is there any tutorial on how to do it?
Thank you in advance,
Greg
