I would like to utilize a SampledProperty like the one in the example below. I would like for the point to continue pulsating infinitely, but can’t seem to do so without changing the bounds of the main timeline clock. I’d like to do so in a way that doesn’t alter the clock. Is this possible? I tried to do so by creating a separate clock solely for the pulsating effect, but am stuck on how to update the time period dynamically for all SampleProperty instances.
Check out the solution for this StackOverflow post: https://stackoverflow.com/questions/42842607/cesiumjs-points-and-css-keyframe-animation
I want to be able to incorporate CZML data, using the timeline to view a specific set of points at a specific time period. The solution in the example sets the clock length to an interval of one second, which disallows me from achieving this.
Chrome, 1.59
